AGM Batteries Q
![](/forums/images/ranks/1k-2k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Time for a new battery on the '71.
Time to loose weight, get a smaller battery and go AGM.
What is the minimum amps needed to spin the starter for a 350?
I had good luck with Odyssey batteries on my other projects.
Anyone having actuall experience with Odyssey, Optima, Deka, Bosch, etc?
![](http://www.corvetteactioncenter.com/tech/images/733_03.jpg)
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
Not much weight saved, unless I have deep pockets.
i3478X
13.4lbs
$1102.49
![](http://cdn3.volusion.com/5cfxm.hxrs6/v/vspfiles/photos/BRB-i3478X-2.jpg?1379654858)
78-PC1500-A
Cold Cranking Amps (CCA) 850
49.5 lbs
USD$ 308.54
i3478X
13.4lbs
$1102.49
78-PC1500-A
49.5 lbs
USD$ 308.54
![](http://mediacdn.shopatron.com/media/mfg/7457/product_image/31a1fff1d50a60834327333c077bbeaf.jpg?1364857014)
I chuckle a bit at times about my battery choice, but several years ago I was scratching my head trying to figure out where I could get some extra weight out of the car when I happened to think about the battery in my lawn tractor (365CA, 300CCA, 16#, $29.95). I hooked the battery up with my jumper cables and it cranked the engine over quite well. Ended up buying one and putting it in the '69. It's on its third or fourth year so far.
For full disclosure, I rarely start the car when it's below 40* (it's not my daily driver) and I've got a lightweight C4 PMGR starter which requires less current draw when cranking. Also, being an old car, it has minimal electronics current drain during storage.
YMMV
YMMV
![](/forums/images/ranks/4k-5k.gif)
batteries lose 10% a year in cranking amps. don't try to match amps to cranking needs. buy the most cranking amps battery you can find and it will start your car for years.
![](/forums/images/ranks/2k-3k.gif)
I needed a battery for my 79, L82 late one Sunday evening. I purchased a Walmart battery as they were the only store open. The battery lasted eleven years. The DieHard I had before only lasted two years.
I've used Optima and have had it ten years. I use a battery tender in the winter but my main reason for this battery is I did not want a leaking battery loosing battery acid on fiberglass.
Just my 2 cents
Just my 2 cents
I've had good luck with the Braille b3121 battery (22 lbs.) for several years now. But I don't drive in winter, only from April through October in good weather. I bought it for the sole purpose of weight reduction, while having a strong battery for the car.
This one...http://www.braillebattery.com/index....atteries/b3121
Always wanted to experiment with one of these Li-Po:
http://www.all-battery.com/148volt-5...-polypack.aspx
Originally Posted by Braille Battery USA
This is the perfect model for those who want to shave half the weight of a stanard Group 34 battery and still have enough power to crank over a large V8. Used in everything from large Harley Davidsons to Corvettes & Vipers.
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
Thanks!
![](/forums/images/ranks/11k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
I noticed the lithium battery was priced at over $1000. I've read that a lithium battery is an option on at least one Porsche...the option costs about $2500. Big bucks for saving weight.
![](/forums/images/ranks/3k-4k.gif)
[QUOTE=68/70Vette;1589385217]I don't think you can just replace a lead acid battery with a lithium battery. The intrinsic plate voltages will be slightly different. The stock alternator voltage regulator will, I would suspect, not work well with a lithium battery.
QUOTE]
The batteries for cars have circuitry inside that make them compatible with vehicle charging systems. Also protection for the cells.
QUOTE]
![](/forums/images/ranks/5k-6k.gif)
YMMV
YMMV
You could buy, what, 10 of those lawnmower batteries for even the cheapest light weight AGM.
Lithium batteries in a car
![EEK!](https://www.corvetteforum.com/forums/images/smilies/eek6.gif)
Improper use like overcharging and over discharging can cause explosion and/or fire. User of the battery is required to have the sufficient Li-polymer charging experience and technical knowledge. Tenergy or All-Battery.com are not responsible for any damage or injury caused by misuse, misunderstanding or abuse of this product.
