too much power?
too much power?
This newer design Dana 36 had a stronger case, all cryo-hardened; lasted about 10 years. I am not hard on my cars.
If I was a betting man, I would bet on that not totally being too much power. I could be incorrect from the pics and lighting but is that some discoloration on the pinion gear pieces? The ring gear I'm not seeing the normal wear that would be present after 10 years of getting on it, so I would question the proper adjustment, especially with what appears to be the machining striations missing on some. I could be off tho from the lighting and pics. Probably shouldn't answer the question without seeing it in person.
Should also ask its maintenance history.
Awful pics. I do see a major wear pattern issue pic 3- Especially the pinion. The rainbow discoloration from overheated. Pic 3
Only pics i currently have avail. Stock Dana 44 with about 180k
Hardened can also = Brittle
Pro Mechanic
That is a bummer though...but 10 years of service from your D36 isn't bad. Now you're "forced" to upgrade.
