Fuel pump
Old 12-10-2015, 12:15 AM
jose7740
jose7740's Avatar
Default Fuel pump
This may have been asked before, can you install a 1985 fuel pump/sending unit assembly on a 1984? What is the main difference between those two?
Old 12-10-2015, 12:21 AM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
I'd guess that they're the same, physically fitting wise.
The '85 pump has produces more volume and pressure, though it's physical shape/size is nearly identical to the '84 pump.
Old 12-10-2015, 01:27 AM
jose7740
jose7740's Avatar
I think I read that they made improvements to the sending unit in 1985 and that is what I am looking for( a more reliable unit ) I am going to give it a try.
Old 12-10-2015, 02:13 AM
Hot Rod Roy
Hot Rod Roy's Avatar
Originally Posted by jose7740
Can you install a 1985 fuel pump/sending unit assembly on a 1984?
Yes. The CFI fuel pressure regulator will handle the extra fuel flow from the '85 pump just fine. No adjustment are necessary. This is a popular modification.
Old 12-10-2015, 10:29 AM
John A. Marker
John A. Marker's Avatar
The 85 pump puts out about 39 pounds of pressure. The 84 system is set for 7-13 pounds.
Old 12-10-2015, 11:23 AM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
That is true, but fortunately, the pressure is managed by the regulator. Pressure is resistance to flow...neither pump puts out any measurable "pressure" when pumping into a bucket (for example). The stock CFI regulator works just fine w/the higher volume MPFI pump...and even more. I ran a Walbro 255 lph pump in my CFI car, factory regulator set to 15 PSI.
Old 12-10-2015, 02:27 PM
John A. Marker
Not debating the need for the regulator. OP just has to be aware that there is a major difference. And perhaps be proactive and put in new regulator if he upgrades the pump. The 85 pump will fill your bucket much faster than the 84 pump.
DAMN sounds like another "bucket list" thread.......
Old 12-10-2015, 03:52 PM
Hot Rod Roy
The fuel pressure in the TPI system would be 39 PSI only if the regulator is set to 39 psi. Put that same pump in a CFI system, and the fuel pressure would be whatever the CFI regulator is set at. No additional fuel pressure regulator is required.
Old 12-10-2015, 10:45 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Agreed. It's a non issue.
Old 12-11-2015, 12:22 AM
jose7740
jose7740's Avatar
I already have been looking for the 85 pump assembly, on eBay they show also a what I believe they call a pulsator, now the sending unit assembly does not show a part that looks like what they are selling, where is that part located? The 84 and 85 pump looks the same, is that something that I will need if I use the 85 assembly or is it something not needed? I have not seen that part listed when looking at the 84 units.
Old 12-11-2015, 12:33 AM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
The '84 likely does not have that part due to the low operating pressure, and the design of the '84 pump. The "pulsator" is supposed to operate like an accumulator, smoothing out any pulses crated by the pumping action of the 85^ style pump. It is not necessary in your '84, but it won't hurt to have it either.
Old 12-11-2015, 12:42 AM
jose7740
jose7740's Avatar
Do you know where is that part located?
Old 12-11-2015, 02:30 AM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
It is typically immediately above the pump's outlet.
...and so it is, on this '88 C4's assembly...
Old 12-11-2015, 12:59 PM
jose7740
jose7740's Avatar
Thank you for the picture
To Fuel pump
Quick Reply: Fuel pump
