Rear aero help with the C4
As most of you know by my random questions I'm relatively new to the world of racing (on full sized tracks). I'm getting my list of things that I need/want to do to the C4 ready for the winter. The car is relatively stable at high speed under power, but during high speed braking, or even just off throttle, it gets VERY tail happy. I was wondering what you guys have seen done on C4s that could get me some rear downforce. Is the best option going to be a wing, or is a lip type of spoiler the better way to go? I'm not opposed to either at this point although from what I can tell, mounting a wing correctly isn't an easy job in the C4 and involves a lot of cutting on the rear body panels to attach it so that it is strong enough and not just some POS bolted to the tail that is going to fly off.
Former Vendor
If you find that you are interested in replacing your rear bumper with a custom fiberglass bumper with a lip, take a look at our custom (part number ACG050).
This bumper also uses C5 tail lights.
This car is also outfitted with a rear wrap.
Our products have not been wind-tunnel tested, so I cannot say how much additional downforce you might gain from a modification like this.
They go for 626.84, but I can do 595.50 for forum members!
Let me know if I can help in the parts department
We noticed a nice improvement with a SCCA Street Prepared legal spoiler on our C4 even at brisk autocross speeds. I'd start with that and see if that is enough, since it is relatively inexpensive to do with some plastic sheet, sandwich it between the rear cap and add a couple of aluminum braces running forward to the area around the rear window.
As you noted wings offer more downforce for less drag, but a decent spoiler might do what you want for a lot less effort in terms of putting in bracing between the frame and body back there.
Solofast,
Any pictures of this setup? What kind of gains did you notice on the auto-x course? We have a very tail-happy BSP car and I've toyed with the idea of a spoiler, but I haven't followed through with it yet. I still like being able to put a cover on the car as well.
red goat: I've had my C4 out on Road America doing 150 at the end of the front straight, and 140+ into turn 5 and 12, and I haven't noticed any tail-happy tendancies. I run into a little power-on oversteer if I'm not smooth on corner exit, and mid corner grip isn't as good as I'd like (I think I need more spring)
That being said, I feel like it's mostly the rake of the car that's helping me. I added about 1/8" to 1/4" rake before my last track day and I had virtually no stability issues even with 3/8" toe out in the front and 38 degree temps.
Solofast,
Here is a video of VIR... if you look at the 00:24 mark you can see what I am talking about going in to turn 1. I know I wasn't perfectly straight because of the other car in front of me stopping short, but it got about that same amount sideways every time. Even a very small steering input under braking makes the back want to come around very quickly, and anything off camber will step the rear out every time. It doesn't really look like a lot, but you can certainly see that it gets twitchy.
...and no making fun of my driving. It was the first time I had ever seen VIR.
I seriously doubt if you have an aero problem with your C4. If you want something to do remove your lisc. plate and vent some air out of the lisc. plate opening. GM wind tunnel tests found that the C4 traps a lot of air in the back. Removing the the plate and opening things up solved the problem.
I run my C4 at both Sebring and on the banking at Homestead and have never felt any need for a huge wing/spoiler on the back. It's more a matter of getting used to driving the car than a real problem.
My basic rule is don't touch the car for the first year. You need to run 6 to 10 events before you spend any money on the car.
Richard Newton
Intervention Motorsports
Richard Newton
C4's are a bit squirrely under hard braking, it's partly (mostly?) a function of rear suspension geometry.
Quite frankly, much of this could be attributed to the car not being pointed straight when you're braking hard. This seems to be the case for me when I'm really pushing it in a braking zone, like at the end of a long straight. If the car is not pointed straight the back tends to step out in the opposite direction than the wheel is pointed.
I'm with Richard. You're new to the car, new to the RR thing. I'd give it time before you start making changes. If you start the mods, you're already changing the variables. Then, when you improve you'll have no idea if you're becoming a more capable driver or if your spoiler really helped. Until you're running lap times consistantly within 0.5 sec or so of each other (barring traffic) making changes is like shooting in the dark.
I especially caution you to consider your long term plans before making changes. As we've discussed in other threads, if you're seriously considering going to the next level soon (time trials or racing) any mods you make now are going to push you farther and farther from a class where you can keep up with the Jones's. You know, the guys that have annual race budgets bigger than our net worth.
Watching the vid my first thought was to high of torque rear brake pads making the rear wheels lock up. Instead of venting the rear, consider a rear diffuser.
Richard Newton
Richard Newton
I actually do run with the plate out because I have read that before. I'm really considering taking the rear part of the Greenwood stuff off because at least by the eyeball test again it looks like it would trap a lot more. As for the first year, I agree, and that is what I have done. The first year is one event from being over and the only thing I changed this year was the brakes, and even that was a safety issue in my head rather than a performance one. I ran this season whenever possible and I have done quite a few events in the car at a few different tracks and with a bit of seat time under my belt I know what I would like the car to do (within reason) compared to what it actually does.
Scary- I'm still looking at where to go with it in the future and at this point I'm leaning towards ST-2 where none of this would matter, or perhaps another year of HPDE in the car as it is and then going through it top to bottom and building it specifically for a certain class.
I don't think it would be too hard to fab up a pretty decent diffuser out of aluminum with the equipment I have access to and a few expert friends. My winter project might have just gotten more interesting.
Aero in the front with none in the rear could deffinitly be part of the problem. Some of the experienced guys should chime in here, but I remember there being a statement that for X number of inches of front splitter, you should have X number of inches of rear spoiler. Aero is a system, so there should probably be something in the back if there is in the front...
No pics, but imagine a piece of flat stock about .125 thick that went from the groove around the hatch, in two places, one near each corner, to near the top of the spoiler at about a 45 degree angle...
Dude if you pull that off I gotta have a how-to. I'd love a diffuser for my C4.
You're absolutely right, if you're going ST2 aero is fine. But I do question your comment that you'd rather tackle aerodynamics over suspension...
Aero is a black art, and very few grassroots guys get it right. Suspension is pretty much a known commodity with book upon book written about it. It would be a heck of a lot easier to read and understand suspension effects than aerodynamics, and even more easy to quantify on track.
Take a look at the "Congrats to Ingle and Bob Mayer" thread. On about page 3 the discussion of aero comes into play. It seems that the wings on Bob and Robert F's cars slow them down more on the straights than speed them up through the corners, and these are $100k+ pro built race cars. It's as easy to do more damage with aero as it is to help you out.
I'm not saying don't do it, just saying make sure you know what you're getting in to, and make sure you can take it off if necessary
Ya know, i started thinking that as well. Looking at the pic in your avatar and based on your comments, you have some front downforce and nothing in the rear. This is definately imbalanced.
EDIT: I know I could get the Greenwood wing... but **** that thing is ugly!
Mine for reference in the front:
Received 1,884 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
What are your rear suspension measurements? Some aggressive chamber and little toe will make it loose. I run -1* chamber and about 1/8" total toe. I have a very neutral car (slight understeer but I still have rubber bushings in the front for the time being).
Tom03Z06:
I'm very interested in that, could you send it to me also? Love the exhaust exits on that car... That's cool. This makes me want to do a whole lot more to my BSP car than is already done.....
