Replacing a Featherlite brake light
Old 05-07-2011, 03:36 PM
Poor-sha
Track Rat
Support Corvetteforum!
Poor-sha's Avatar
Received 3,415 Likes on 1,380 Posts
Default Replacing a Featherlite brake light
Got my car all loaded up to go to WG tomorrow and did the usual walkaround of my trailer. Apparently one of the brake lights is out. It's just one element on one bulb so I'mn pretty sure it's not the wiring. The problem is that the bulbs are in this sealed clear plastic pod once you get the amber cover off. It doesn't appear to come apart but obviously it must. Any ideas?
Old 05-07-2011, 05:11 PM
dvandentop
dvandentop's Avatar
cover should jsut pop off i would think try a small flat blade screw driver along the top or bottom edge
Old 05-07-2011, 05:39 PM
JDIllon
JDIllon's Avatar
It also could be a sealed water tight light? In which case you will have to replace the entire unit. JD
Old 05-07-2011, 05:51 PM
davidfarmer
davidfarmer's Avatar
I agree with JD, I think you have to replace the entire unit.
Old 05-07-2011, 06:20 PM
Z11409
Z11409's Avatar
Unit replacement,trailer or truck parts.
Old 05-07-2011, 09:53 PM
Poor-sha
Track Rat
Poor-sha's Avatar
Well that's not very convenient. I found the replacement unit online but obviously this won't help me tomorrow.
Old 05-07-2011, 10:04 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Autozone has trailer tail lights.
To Replacing a Featherlite brake light
Quick Reply: Replacing a Featherlite brake light
