View Poll Results: Which 2-piece rotor is best for the track?
Voters: 27. You may not vote on this poll
Best 2-piece rotor: vote!
![](/forums/images/ranks/3k-4k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I went from stock to Wilwood 2-piece and I like the change. The cost is a lot more though. Their setup is light, not just because of the aluminum hats. It does help with cracking a lot. I had DBA and they are fine if you can deal with a lot more unsprung weight. They are very heavy.
![](/forums/images/ranks/2k-3k.gif)
Was pretty awesome overall. You should have a kid call up hitco and beg
![Smile](https://www.corvetteforum.com/forums/images/smilies/smile5.gif)
![](/forums/images/ranks/500-1000.gif)
![Big Grin](https://www.corvetteforum.com/forums/images/smilies/biggrin5.gif)
Regarding DBA pricing, I'd recommend contact KNSBrakes. I believe his prices for rotors are better than tirerack's, and the rings cost a lot less than whole.
Supporting Vendor
The c5 DBA two piece weigh in at just under 19 pounds. Centric standards one piece are about 17.2 or so.
I have about nine track hours on the fronts
