Assembly Manual nomenclature (P Washer ; L Nut)
What type of washer is a "p washer"?
What type of nut (assuming locking nut but didn't think nylon ones were used) is a "L nut"?
Thanks,
John
Thanks,
John
It's been too many years since I looked at an AIM for assembly guidance at that level.
Received 1,861 Likes
What makes it confusing is the manual has "washer"and "p washer" as if there was a difference. Sometimes says to use "washer" and other times "p washer".
Sometimes it would have the "p washer" followed by a L Washer and visa versa. Other cases would list just a plain "washer" without the "p".
Jeff (62Jeff) the context was used in many pages such as the AC brackets and even the throttle bracket.
Thanks everyone for confirming what the P meant. Still wierd though if not needed to differentiate.
Not to but on a same page an engineer used a "Washer" with a "L Washer" and a "P Washer" with a "L Washer" as if he was truely differentiating the two types of washers and what type to use at each location.
Went also to a 1969 assembly manual (none Chevy) and they also used "P Washer" as well as just "Washer".
Not disagreeing the P Washer is a plain washer as stated, but the engineers did use the two names for differentiating purposes that I don't understand.
