My hood keeps popping open?
Banned Scam/Spammer
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
My 64 hood keeps popping open. Had some work done and now this. Yes the hood was off (I guess thats as good as they get, inside joke)! I tried to change the pins with another set. Can anyone shed some light on this. I am thinking the actual latch is bad but not sure if I should order a new one? So before I do perhaps someone has had the same problem.
Thanks as always.
Sixty4....Mark.
Thanks as always.
Sixty4....Mark.
You ARE pushing the hood release handle all the way back in after pulling it out to unlatch the hood, right?
If so, then all I can figure is the hood is not properly aligned?
![](/forums/images/ranks/1k-2k.gif)
Yeah its a pain. Mine pop one side or the other when I hit a big uneven bump in the road. I spent a bit of time adjusting the hood pins and hood stops which reduced it a bit however on a really big bump they still go. Probably need new hood latches (or the springs that hold them shut).
Cheers,
Bob
Cheers,
Bob
Banned Scam/Spammer
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
Banned Scam/Spammer
Cheers,
Bob
Cheers,
Bob
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
![](http://i278.photobucket.com/albums/kk114/rcktman1_album/65%20Corvette/PassengerHoodLatch.jpg)
![](/forums/images/ranks/100-500.gif)
64Jeff ... I'm having the same problem. Driver's side pops open. Our commonality is that I also had the hood off. The latch was fine before that. I've turned the male pin around to see if it would catch better on an unworn spot. No good. I'm going to try to adjust the hood a tad to see if that helps. I believe there are some other suggestions on this topic in previous posts (adjusting the female latch, using tin foil to see how the latch lines up with the pin, etc.).
Banned Scam/Spammer
Passenger side....
![](http://i46.photobucket.com/albums/f126/mwstahl/DSC01097.jpg)
Drivers side......
![](http://i46.photobucket.com/albums/f126/mwstahl/DSC01098.jpg)
One thing I did notice when taking these pics with the hood half way up it seemed like a lot of side to side play on the hood? Front hinges?
Thanks again!
Drivers side......
Thanks again!
Banned Scam/Spammer
I tried spinning the male pin myself, I am going to see if I can find that thread! Even tried shaving the female latch for some bite, (that don't sound good anyway I type it lol).
The female part is probably worn if the above ideas don't work. Therfore it's loose with no grip. I believe I saw it on here where somone built it up and the latch was almost straight across. Not like a crescent moon shape in your pictures. I would try another female component.
![Big Grin](https://www.corvetteforum.com/forums/images/smilies/biggrin5.gif)
Good luck.
![](/forums/images/ranks/7k-10k.gif)
Your problem is probably the female hood latches beeing worn, or at the least, the springs being weak. If they are original hinges, changing them can't hurt. Mid year hinges seem to get very sloppy with age, which will cause the hood to move around a lot. If you replace the hinges, make sure to get the US made ones that Paragon makes, and not the foreign made ones from Corvette America.
That sure sounds suspicious. If the hood can shift to the passenger side it may move enough for the male pins to clear the female latch and spring open.
![](/forums/images/ranks/2k-3k.gif)
Hi: I had the same problem and found a fix for mine. The bracket that holds the hood release handle was bent back toward the seat and causing too much tention on the hood release cable when the hood was closed, causing it to pop open on bumps on the road. I bent the bracket a little, pushed it toward the engine and problem fixed!
Dave
Dave
![](/forums/images/ranks/5k-6k.gif)
Hi,
Had same problem for many years. After much doing what everyone had suggested, I realized that you can not have tension on the cable that goes from Driver Side to Passenger side. Open hood, make sure handle is pushed in , loosen cable stops on drivers side, and let the passenger side latch extend as much as the spring will take it. With no tension on from latch springs, tighten cable stops.
I found that when you over load latch springs, they will release on hitting a bump.
Try it. My latches and wire cables are original and I thought I needed new ones. You do need to replace the hood hinges, or rebuild them. The center bushing will wear out causing excess movement.
Jack
Jack
![](/forums/images/ranks/11k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
Received 1,862 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
1. Wrap a piece of aluminum foil over each latch and gently lower the hood until the striker pins touch, to verify that the latches are correctly positioned - if not, adjust them. Lube the moving catch plates so they move freely.
2. Adjust the rubber bumpers - all they do is position the hood up-down to set the flush relationship to the surround.
3. Loosen the round lock nuts on the striker pins and adjust them so you get proper engagement in the latches, and re-tighten the lock nuts. Done.
Were the springs in those female latches ever replaced? From your photos, they don't look like they have much tension. In the closed position, there should be a bit of tension on those springs to hold the latch closed tightly.
Pilot Dan
