Trailer hitches for C1 and C2 Vettes?
#43
![](/forums/images/ranks/5k-6k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Ron ..
If you might be so inclined, could you expand a bit on the design of your hitch?
From your pic it appears there are bumper mounted brackets, then the main load carrying U-shaped member support piece bolted to that. .
From the U shaped support bar does a center positioned longitudinal bar (or some such) tie the U shaped support bar to the rear end camber adjustment bracket? . . Very much interested in this design. . .![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
![](http://i32.photobucket.com/albums/d18/rlmiller339/66%20Convertible/IMG_1746.jpg)
Here's a pic as well of the attachment at one side of the "U" bracket. Each side is attached by a bolted link by removing one of the bumper bolt attaching bolts, no holes are required to be drilled in the bumpers, and the installation can be completely reversed with no changes to the original construction.
![](http://i32.photobucket.com/albums/d18/rlmiller339/66%20Convertible/IMG_1745.jpg)
I don't have a good photo of the attachment of the drawbar at the rear differential, but there is essentially two separate pieces bolted, one to each side of the spring attaching bolts, and the drawbar is connected with a single through bolt between these two which allows the drawbar to pivot down. Clear as mud?? Here's a halfway explanative photo that may help, although it was taken for another purpose . . . . .
![](http://i32.photobucket.com/albums/d18/rlmiller339/66%20Rear%20Rotor%20Removal/IMG_1261.jpg)
Hope this helps somewhat . . . . let me know if I can help further!
#46
#47
Well, thanx to VERY generous Ron (Cruzmeisters), I have a hitch for my Wife's '61 on it's way here and she'll be able to tow her C1 Corvette go-kart on a small trailer... Much thanx to all of you who gave me advice and especially to Ron who made it happen...
David
David
#48
![](/forums/images/ranks/100-500.gif)
Well I finally found mine hitches....
I have one that bolts to the rear bumpers (requires holes in bumpers) for 63-67?
And the other has stamped 68-71 and is made by Draw Tite, probably fits other models.
Then I have two brackets that I am not sure but looks like previous post that allow the hitch to pivot? must be for another hitch?
I really need to go thru and get rid of a bunch of stuff from a corvette salvage yard I bought out in the early 90's.....
Not much left, seat belts, pulleys, brackets, etc
![*****](https://www.corvetteforum.com/forums/images/smilies/willy_nilly.gif)
#52
4th Gear
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
I have a couple of original corvette hitches in the shop if anyone needs em PM me with your email & I can send pics.....
A buddy & I bought out a corvette salvage yard in the 90's sold almost everything but have some small items left over, seat belts, pulleys, water pumps etc....
Wish the internet would have been around then it would have been a lot easier than swap meets...
Thanks, Ed
#54
![](/forums/images/ranks/7k-10k.gif)
Received 3,805 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
#55
Cool thread! That valley unit appears to be what I ended up with on my '66.....I'm keeping it as it really sets the car apart.
