66 big block started running like crap
Got ready to get the big block going down the street today. Blead brakes,put on steering wheel,Started car up running beauitful,choke working fine and running great...This is a project started last year.Everything done on motor,new 3370 carb,valve job,all new gaskets etc.et. by the way 437-390 HP. adjusted valves last week, car was running great.After it warmed up today,started going down the block running great,turned around started back home got on it a little,started to miss. Checked it out when I got home 3 cylinders not firing way to rich. Pulled out the 43 plugs put 45's in same thing,checked cap and rotor both ok.carb and timing were dead on before this started.have a funny feeling valves need adjusting, Any IDEAS of an easy way to adust the vales without making a mess with the motor running.Tried an old valve cover with holes in it still makes a mess...
remove the valve covers and look for a broken spring, bent pushrod and the like...also check for a bad intake or carb gasket
follow the sticky and adjust the valves with the mill not running
setting lifters while running is a waste of time and oil although others swear by it.....
valve adjustment
sounds like something may have let go when you jumped on it
Hard to believe that valves came out of adjustment on three cylinders at the same and relatively short time. Are the cylinders adjacent to each other?
on each cylinder, set the intake when the exhaust STARTS to open
set the exhaust when the intake is FULLY OPEN AND "STARTS" to close (come back up)
Yeah - if you really have 3 dead cylinders from what you believe to be a too rich condition, I think I would be looking at a fuel problem. Maybe a needle and seat has trash on it and is not sealing - and flooding the carb. If a 427/390 it would have a hydraulic cam if stock - unless this is a new engine and you wiped out the cam I don't think running the valves will help.
Gerry
I guess you could use this. Post # 7:
http://forums.corvetteforum.com/c1-a...djustment.html
Or this:
http://www.lbfun.com/warehouse/tech_...ch%20paper.pdf
Gerry
Or this:
Gerry
found problem
bb pushrods are tough....check for bad springs or the wrong springs for your engine..(coil bind comes to mind)
with out finding the cause, you are more than likely to repeat the failure and maybe not so lucky the second time around.....
also look for cut rocker studs...could be the wrong rockers for a high lift cam
figure out first, WHY did the pushrod bend???
I think what happened is the car sat for a long time,I adjusted the lifters and one wasn't pumped up all the way and when I drove down the block, it pumped up and bent the pushrod. Everything is stock and new.I'll see when I get the new one and try again.Thanks for your help..
How would the plugs get fouled? With a bent intake pushrod I would assume the intake valve is staying closed or not opening all the way. In either case there would be no extra fuel or oil in the cylinder, or am I missing something?
Gerry
Gerry
maybe he did over adjust his lifters, but he would have to bottomed out the plungers and then kissed a piston with the valve ??..bwdik
Fixed
could be a bent valve ( intake) with blow back into the intake runners, polluting other runners with the intakes starting to open or fully open in other cylinders,....
