What does this mean?? CE Block
![](/forums/images/ranks/1k-2k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I was looking at an add for a 67 427 390 hp car and it says the following:
It has a service replacement CE block [it is a XXXX289 block], from Chevrolet. Do not have the original XXXXX351 block. This block is the same bore as the original [4.250] and is built with the same spec. cam, crank, rods, pistons comp ratio, etc., as original. It is a 390 HP engine.
Somebody please translate this??
![](/forums/images/ranks/5k-6k.gif)
![EEK!](https://www.corvetteforum.com/forums/images/smilies/eek6.gif)
![Big Grin](https://www.corvetteforum.com/forums/images/smilies/biggrin5.gif)
![](/forums/images/ranks/100-500.gif)
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
Chevy dealers sold a lot of Hi-Perf short blocks and long blocks over the parts counter long before todays "CRATE" motors.
Also as noted warranty - Dodge Plymouth went thur a bunch of 440's when that block came out in 1967 - Chevy / Pontiac guys bought new GTX's and Dodge RT's and tried to pull 6000 rpm like a GM small block
Blue
![](/forums/images/ranks/3k-4k.gif)
Not 'probably', I'd say 'possibly'. There's tons of CE blocks around, being that they were not unique to Corvette, and it's a great temptation to slip one into a Corvette using the line that it was warranty replacement. In turn, this magically makes it a 'semi-matching number' car. ![Big Grin](https://www.corvetteforum.com/forums/images/smilies/biggrin5.gif)
![Yes Nod](https://www.corvetteforum.com/forums/images/smilies/yesnod.gif)
Earl
![](/forums/images/ranks/7k-10k.gif)
............Crated Engine. Had one back in the day and was told that by the dealer/parts guy that I bought it from. Dealers installed them as warranty replacements for engines that "failed"; you could also buy them over the counter and install them in whatever.
Mine was a '70 LT-1 engine that I put in my '67. It came in a crate, not in a car! Hence the "CE" designation.
Just because a block has a "CE" designation doesn't mean it was a factory/dealer/warranty replacement, unless there is some other documentation ( service order, receipt, etc.) to prove it!
Admittedly, my understanding of the definition is second hand - and 40 years old! Since there are now two opinions - "Counter Exchange" and "Crated Engine",
Maybe a real expert like John Z could weigh in and set us all straight?
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
![](/forums/images/ranks/11k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
Received 1,862 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
This is post #3, at least using metric numbers.
Did you read post #11
{nope! CE means Chevy engine}
Blue
Is there a list or resource to date or get more info on "CEs". I've been told an engine is a "factory replacement" likely from 72, but I don't know where that info comes from. The older post states that the numbers could be the total number or a year code of some sort.
http://www.camaros.org/engine.shtml#service
Hit That! (10-10-2017)
![](/forums/images/ranks/2k-3k.gif)
