I put a duel master cyl. on my 63
![](/forums/images/ranks/11k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
Received 1,862 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
80% of midyear production had manual brakes, including my '67; don't confuse the extremely low pedal effort on your modern daily driver with power brakes with the pedal effort on an old manual-brake Corvette. If someone who had never driven anything but a modern car drove my manual-brake '67, they'd probably say my brake pedal effort was WAY too high, and there must be something wrong with it. Modern cars with low pedal effort have spoiled us.
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
![](/forums/images/ranks/5k-6k.gif)
Let me describe the "effort."
The pedal is nice and high from the floor. You push the pedal and the effort seems fairly normal at first, though a bit hard.
As the pedal is depressed the effort gets harder, as expected.
When you get to the point where you would expect the brakes to lock up, they don't. You find yourself squeezing extremely hard for that last bit, but the lock-up never really seems to come.
Of course this is unnerving as you are getting closer and closer to the midyear bumper in front of you.
![EEK!](https://www.corvetteforum.com/forums/images/smilies/eek6.gif)
![](/forums/images/ranks/2k-3k.gif)
as John Z says the 63/64s have a 7/8th bore all later C2s are 1". a 7/8 master is very unusual. i switched to a duel master with drum brakes all around on my 64. i used a 77 monza master, it has a 7/8th bore on both sides, thus no increased pedal pressure. the 77 monza is non powered, it works like a charm. the monzas were front discs, so you either have to install a check valve in the master or a check valve in the front brake line. it works great. i did a write up on the mod in detail in 2007 or 2008 on the C2 forum, do a search...
Of course this is unnerving as you are getting closer and closer to the midyear bumper in front of you.![EEK!](https://www.corvetteforum.com/forums/images/smilies/eek6.gif)
go with the monza master, and if you ever follow to close to any of my cars, expepte a beat down
so you drive behind other midyears too closely, where does that ever happen. in my pantera i would just blast off and leave you behind. but if you crashed into my vette. you were following to closly so it is your fault.
My research on the Monza has only turned up M/Cs for use with a "flush" pushrod, as is done on the power brake Corvettes. I've even posted a link to a Monza M/C here and will do it again. They are fairly cheap to obtain rebuilts.
The non-power Corvette needs approximately 1.65" of pushrod depth. I've not seen a depth listed for the non-power Monzas. Perhaps you have a reference?
![Big Ears](https://www.corvetteforum.com/forums/images/smilies/bigear.gif)
http://cgi.ebay.com/ebaymotors/Wagne...Q5fAccessories
Not a matter of following too close. Its a matter of not getting the most out of the brakes.
The non-power Corvette needs approximately 1.65" of pushrod depth. I've not seen a depth listed for the non-power Monzas. Perhaps you have a reference?![Big Ears](https://www.corvetteforum.com/forums/images/smilies/bigear.gif)
TOD. just adjust the pushrod to fit the master. i built a flat firewall for my car, with the monza master i had to make a one inch spacer and install it with corresponding longer bolts welded to the pedal bracket that goes under the dash. i then sawed the head off a 2 inch grade 8 bolt and gound it so it looked like this U on the end. adjusted it to fit with 1/32 clearance, you do know that the monza master has different sized brake lines. a doulble flairing tool and a tube bender is needed for the install...![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
Great. Sounds like a simple "bolt on," "screw-up" that will look near stock.
![Leaving](https://www.corvetteforum.com/forums/images/smilies/leaving.gif)
![](http://www.largescaleonline.com/eimages/lsolpics/Team_Member_Pics/toddalin/Parts/Alternator_Brace_6.jpg)
