1959 FI Heads
![](/forums/images/ranks/3k-4k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
This is also a 3755538 head. It seems they made different configurations. It is thought this was made for a truck and had bosses for items found on larger trucks. I am just relaying info I found researching online but it seems plausible.
![](/forums/images/ranks/2k-3k.gif)
looks like two different heads, left head on photo shows accessory boss not used until somewhere in 68 the other twin smoke stacks are period correct buuuut the casting number and dates tell the real story.
rustylugnuts
rustylugnuts
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
![](/forums/images/ranks/11k.gif)
Received 1,283 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
Some 58-59 and perhaps 60 cylinder heads have accessory holes for the air pump that was part of the factory air ride suspension system.
These heads are pretty hard to find, but not necessarily desirable.
The 1957 539 heads, correct for 57 Corvette with FI, are fairly common. These same heads were also used on passenger cars with power pack single four barrel.
them heads have the same emblem on the other end . thats the way mine are. they have the twin smoke on opposite ends
Here are the heads I have. These are 59 corvette fi heads / marine. I guess chris craft tapped the water ports ?
![](/forums/images/ranks/7k-10k.gif)
Received 6,807 Likes
C2 of Year Finalist (track prepared) 2019
Every solid lifter, injected engine made from '57 through '60 that I've inspected has had single pyramid "Power Pak" heads. I've inspected a lot of injected engines.
Jim
jerry gollnick (12-12-2016)
Jim here is paperwork. See what you can figure out. Im no expert this is what I see in black and white. Maybe they are wrong who knows bud
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
Received 1,862 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
no but I read up on chris craft and they bought the corvette motor from gm and put in boat straight from factory. block 3756519 with these heads. my dad bought this boat new back then, it is original motor. 59 283
#33
here is a pic. Like I said jim im no expert. I would like to know more.It says they put high performance parts like a truck or rv cam for more hp for the mahogany boats
#34
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
Rumblegutz (05-03-2023)
#35
![](/forums/images/ranks/500-1000.gif)
Looks to me from the color of the engine in these pics I would say it is a Truck Specific engine,,The truck parts don't usually show up in any of the usual engine parts books
