single stage or bc/cc
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
This winter I am getting the car ready to shoot.I am looking at either single stage or bc cc.It will be black Any suggestions...Vince
![](/forums/images/ranks/3k-4k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
It depends on what you want to do with the car afterwards. I went with BC/CC as I was never going to have the judged NCRS. The BC/CC is a lot easier to work with. I have wet sanded my car on about 3 or 4 occasions to smooth out some imperfections and I still haven't gone through the CC. JMO
![](/forums/images/ranks/5k-6k.gif)
Depends upon the material. If you are shooting this in the garage, and depending upon mil thickness you might do 2-3 coats of base, IF needed, sand out any trash and apply more base coat, then shoot 3 coats of clear, depending upon the clear you may want to sand and then shoot two more, sand and buff if the material allows it. Just depends on what look you are after and if the material allows it.
Depends upon the material. If you are shooting this in the garage, and depending upon mil thickness you might do 2-3 coats of base, sand out any trash and then shoot 3 coats of clear, sand and then shoot two more, sand and buff if the material allows it. Just depends on what look you are after and if the material allows it.
Jim
Received 1,532 Likes
C1 of Year Finalist (stock) 2019
2018 C1 of Year Finalist
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
Depends...
depends on the quality of the material and how it hides
Basecoat 2-3 coats - I nomally shoot 3 - 4 coats of base
Clear 2 - 3 coats - 3 coats if your going to do alot of wetsanding
and optional
after the car is based and cleared
wetsand the car again with 800 to 1000 - 2 more coats of clear - the wetsand that with 1000 1500 2000 3000 and wear your sun glasses
and optional
![cool](https://www.corvetteforum.com/forums/images/smilies/coolgleamA.gif)
The number of coats of base depends on the paint. All you need is total coverage. What may take 2 coats with one brand may take 4 with another. As far as the clear goes, it depends on the clear, your gun and the application. With a good quality clear, 3 coats usually is enough to allow you cut and buff. ![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
Jim
Jim
![](/forums/images/ranks/7k-10k.gif)
Received 2,197 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
I heard recently the they are not going to deduct any points for 2 stage anymore?
![](/forums/images/ranks/4k-5k.gif)
While the depth of gloss is probably a little higher with BC/CC, I am a big fan on single stage for all non-metallic colors. It can be color sanded and buffed just like clear coat, and is way easier to touch up. A properly cut and polished Single stage job will have a depth of gloss that is comparable to a BC/CC job.
About the only time I shoot BC/CC is for metallic colors. It is probably more expensive for most colors in single stage, especially red, but it is worth it to me. With BC, you do not have to put as much of the expensive red pigment down as you do with the single stage, and the clear is WAY less expensive. Touching up nicks and chips is tougher my cars is a annual event, and it is just so easy with single stage urethane.
Regards, John McGraw
![Big Grin](https://www.corvetteforum.com/forums/images/smilies/biggrin5.gif)
![](/forums/images/ranks/2k-3k.gif)
No one has suggested single stage color sanded and clear coated. I shot single stage on my 29 Ford and then decided to clear coat it. The clear is much harder to sand thru. On a few parts I didn't spray clear like the louvered hood. On the top irons I left the single stage uncleared. I cleared all the major body panels.
When I ordered my PPG Concepts a couple years ago I really didn't know what I was doing, Model A forum members suggested the single stage. I changed my mind when I painted recently and shot clear as well.
My 63 has base/clear put on by a pro shop.
I can't, for the life of me, understand why anyone would paint a car using modern materials..............especially in BLACK..................and then fu*k it up by making it try to look like lackey!
Paint the damn thing in BC/CC, enjoy the deep, mirror, "wet black glass" finish. Enjoy the oooohs and aaaaahs of admirers
, and don't look back.
There is NOTHING like a BLACK car in BC/CC!
Nothing.
If you wanta make your car nice and ugly for the NCRS, then paint it in lackey.
![EEK!](https://www.corvetteforum.com/forums/images/smilies/eek6.gif)
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
Nothing.
http://i1222.photobucket.com/albums/...g?t=1318978887
Scratches show up white in CC/BC black. They show up black in SS black. If it's a garage queen it might not matter. If it gets some regular use and is exposed to some daily grind and wear it might make a difference when washed up.
Over in the Paint and Body area under General Corvette you can do an advanced search for threads on "black paint" and get a number of discussions on this subject. I was impressed by the nearly universal agreement of the body and paint experts that inhabit that forum (Dub and Porchdog) in addition to prior posts by John McGraw to use single stage (PPG Concept) on the black car I just painted. I wish I could say it's just about the shiniest and clearest black finish you have ever seen but I'm still color sanding in preparation for buffing.
Dan,
The other real advantage of the single stage urethane is, if you should sand through when color sanding, you can mix up a little more black and just spot paint the area. By the next day, you can sand and buff that area, and you will never see the repair. If you do this with BC/CC, you will have to shoot some more base, followed by clear blended out on the panel, and there is still a chance that you will see the edge of the clear when you buff it out. The only sure-fire way not to see clear edges, is to clear the entire panel from edge to edge. This can be quite a problem on Corvettes where the panels are not individual panels like they are on steel cars.
Dan,
You know I had this come up on my car I just painted when I found a thin area on a fender lip that I managed to hit lightly on all 4 passes arond the car and exposed sealer in color sanding. I got so many varying opinions on the Paint and Body forum about trying to spot it and blend it in - I looked at blending thinner, etc - that I finally just feathered in a couple coats over the area and then re-shot the entire body with two more complete coats of black. But, I'm glad to hear from experience that it can be touched up and blended in to be virtually invisible.
