Fuel tank felt anti-squeak cement
Old 02-03-2012, 09:25 PM
Dave Tracy
Dave Tracy's Avatar
Default Fuel tank felt anti-squeak cement
I have checked my assembly manual regarding the cementing of the felt anti-squeak felt to the fuel tank. The manual states that 9981098 cement be used. What kind of cement is this or what is recommended to use now? Thank you all in advance for your advice.
Old 02-03-2012, 09:34 PM
5thvet
5thvet's Avatar
I sparingly used the 3M Black Weatherstrip Adhesive to glue my strips down to the frame before installing the tank. Worked great.
Don
Old 02-03-2012, 09:47 PM
1snake
1snake's Avatar
The felt strips on my 65 were glued to the tank with yellow adhesive. Probably the same stuff they used on weatherstrips. I used the black 3M W/S cement to glue the new ones on.
Jim
Old 02-04-2012, 12:00 AM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,816 Likes on 1,461 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Jim
The 3-m yellow is a close substitute, but the actual stuff was a bit darker than the 3-m. But hey.. who is going to see it..
Black or Yellow the 3M will work just fine.
Old 02-04-2012, 08:47 PM
Dave Tracy
Dave Tracy's Avatar
Thank you all. I just bought the yellow 3M adhesive. Will get at it tomorrow.
Old 02-04-2012, 08:53 PM
Hitch
Hitch's Avatar
Just my .02... When I replaced my tank all I used was roofing paper and they are held in place by the straps..
David
Old 02-05-2012, 06:52 PM
Mark_Milner
Mark_Milner's Avatar
David
30 lb roofing paper and cut it to fit.
Good to go.
I believe the original stuff was about twice that thickness, so I have used the 20 lb and doubled it up before.
Old 02-05-2012, 07:19 PM
cor66vette
cor66vette's Avatar
Received 1,309 Likes on 690 Posts
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
David
Good to go.
To Fuel tank felt anti-squeak cement
Quick Reply: Fuel tank felt anti-squeak cement
