converting 63-66 back up to stop & tail lights
![](/forums/images/ranks/500-1000.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
If converting the two inner reverse lights to stop and tail lights, do I need to change the chrome housing,
or just the lense globe and pigtail ?
![](/forums/images/ranks/7k-10k.gif)
Received 2,197 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
Replace the single socket with a double. They just twist in from the backside of the housing. Wire new double pigtail to outer and install 1157 bulb and red lens.
![](/forums/images/ranks/5k-6k.gif)
Received 1,309 Likes
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
If you want the two inner lights to function as directionals ONLY, then just power the socket from the directional feed and leave the socket as a single prong. And vice versa, if you want them to function as brake lights ONLY, tap into the brake feed. As Vega$Vette stated in the prior post, you'll need a two prong socket and 1157 bulb if you want them to act as turn indicators AND brake lights.
![](http://i445.photobucket.com/albums/qq176/anychevy/Other%20stuff/corvette/ZIPtaillightpigtailE-399.jpg)
The bulb and lense in a no brainer.
Just twist the existing pigtail out. Turn counter clockwise looking from the rear or clockwise looking at it from the side the pigtail goes into.
Twist in the new one, tie in the wires and you're good.
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
For now I just changed the inner position lenses from clear to red and spliced the brake/turn signal circuit into that socket. With lights on there are two tail lamps. When you hit the brakes there are four brake lamps. Kind of like having a third brake light to draw attention. When you use the turn signals whichever side is blinking blinks two lamps.
When I bought the car it had a single pigtail and a 1156 bulb in the inner lights with a red lens. I replaced it with a double pigtail plus the 1157 and it all works perfect.
Maybe there was a single pigtail stuck in a double housing but both the 1156 and 1157 bulbs plugged right in.
So, do I need complete inner tail light assemblies to make this work (properly) or not ?
During daylight hours it just looks like a normal four tail light vehicle as signals and brake lights all come on. At night the change from a two tail lamp vehicle to a four brake lamp vehicle or the change from one to two turn signal lamps catches your eye.
I'll see if I can get a friend to take and post some video.
The more lighting I have (day or night) at the back of the car, the better.
I understand making the 2 inners either brake & indictor, or just tail lights would be the easiest solution, but I'm trying to convert them to stop & tail, so they do the same job as the 2 outers, as on a 63-65 without backup lights.
![](/forums/images/ranks/3k-4k.gif)
Good idea, What will you use for back up lights afterwards? I was thinking along these same lines and mount some white LEDs up under the rear pan out of sight that would illuminate the ground.
Bruce
Bruce
