driveline alignment
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I replaced engine mounts and built a tranny mount for my ROD 6speed. I hope with all the knowledge on this great forum someone can tell me how to check the engine and tranny alignment side to side. I set the diff-tranny offset at 3 degrees but setting the tranny in the middle between the original tranny/frame mounts looks "wrong" Is the a measurement from the frame rails to the tranny certerline? I have 1 7/8" offset now. Help Needed Thanks for anything, Keith
![](/forums/images/ranks/11k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
Received 1,862 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
If you have the transmission mount in the same cross-car location as the original, that's all you need; the midyear Corvette driveline was offset about an inch from centerline to the passenger side.
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
