[C1] Best ifs system
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I am about to purchase an ifs system, but i see several on the market. I need one that will fit with shorty headers. I have been looking at Corvette centrals and Jim Meier in particular. Can't see much difference in them. Are these the best and any issues with them. Are there others that are better?
63split63 (01-02-2017)
There was a company in Canada called MacGyver, but they seem to be out of business.
Last week I visited a company called Coffman Corvettes, located in Mansfield Ohio. The owner has agreed to build a custom IFS for me using C6 Corvette parts with coil over shocks. It should be complete by sometime in March. I'll let you know how it turns out. You can PM me for more info.
Marty
tonymcilroy (01-02-2017)
![](/forums/images/ranks/7k-10k.gif)
St. Jude Donor '07
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
You didn't say what year C1 you have. I have a 62 and I also have been looking for a new IFS (Independent Front Suspension). The Jim Meyer system uses Mustang parts, there is a company Martz Chassis located in Bedford PA that makes a Bolt on system for C1s they use Camero parts.
Marty
Marty
from a pure bolt-on standpoint, the Meyer is probably the easiest (and probably the most expensive)
I ended up going with the TCI 'kit'..
the TCI is very OLD SCHOOL, but once installed, it works. the clunkiest part is the way camber/caster is set; but once set it is as good as any...
a thought about using C6 parts... I wouldn't go that route without doing something to the rear brakes; you will have too much brake on the front. although not needed with the typical C1 IFS conversion, I installed rear disc on my 62. if nothing else.. it's 'cool'...
Bill
back when I was looking, I kinda sorta liked the MacGyver; but, as you have apparently learned, they seem to be out of business.
Bill
Bill
I didn't like either of the bolt on options because they both contain custom made spindles and other parts, where the C6 parts are readily available, if the need should arise.
Marty
St. Jude Donor '07
Bill, I installed disc brakes Front and rear about 10 years ago, then I added Jim Meyer Power brake unit. This unit made the car much easier to stop.
Marty
Marty
![*****](https://www.corvetteforum.com/forums/images/smilies/willy_nilly.gif)
Bill
![](/forums/images/ranks/3k-4k.gif)
The only problem I had with JMR unit was a broken weld on the cross member. They did supply me with four gussets to weld in place after contacting them. Since you'll be buying a new unit they should be already welded in place.
I did have to replace one adjustable QA1 shock. Unless your racing save a little and buy the non adjustable ones. I might also suggest putting in side motor mounts while your at it. You will have to paint the unit parts. I used Rustoleum silver hammered and have been pleased with how it has held up over the years.
![](http://i35.photobucket.com/albums/d160/62f79/Corvette/DSCF3626_zpsdv9z3bzh.jpg)
If you click on the picture it will take to other pictures.
![](/forums/images/ranks/4k-5k.gif)
Received 1,995 Likes
This looks good Richard! Very nice!
Pat
Pat
C-1 Generation 2 (01-04-2017)
