[C1] 53-74 Electronic Tachometer conversion kit - any reviews/opinions ?
Considering an electronic tach for our 58...Corvette Specialties is only vendor I find who sells one that is plug & play and price is $435, ouch.
This kit is available from a few vendors, priced at $160 and description reads " Simply remove factory tachometer from cluster and mount the new electronic module on the back of your original tachometer face."
Here's the one Zip sells-
https://www.zip-corvette.com/53-74-e...rsion-kit.html
Was planning to have the original rebuilt but I'll likely have $350 in that and its generator driven, dunno if I'll ever decide to upgrade the charging system with an alternator but if so having an electronic tach wouldn't be an issue.
Anyone have any experience with these electronic conversion kits, or thoughts, pros/cons of them ?
Thanks-
Ryan22
Thanks-
Ryan22
Related question; here's the install instructions-
https://www.zip-corvette.com/amfile/...product/16701/
#4 talks about a "signal generator", can someone clue me in on this ?
Thanks-
Thanks-
I think a signal generator refers to something the ECU puts out, assuming your engine has one and isn't carb'd.
Otherwise, you generally hook up to the low voltage side of the coil.
Doug
Doug
ryan22 (12-04-2019)
Thanks-
Thanks-
10 minute job...
This tach operates off the negative terminal of the ignition coil just like every aftermarket tach that we put in as teenagers decades ago..
ryan22 (12-04-2019)
Received 1,310 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Frank is right.. the signal generator is lab equipment used for calibration.
Thanks-
Thanks-
That conversion should work just fine with points if the green wire goes to the negative terminal of the ignition coil...
Green= This is your signal wire, on a distributor 8 cylinder this will go the negative side of the coil. On a LS engine or a MSD ignition it will connect to the Tach output wire from the corresponding box.
ryan22 (12-08-2019)
Every old Sunpro tach I hooked up in the 60s to points cars worked just fine off the negative ignition coil terminal...
Received 1,861 Likes
VDO also makes a small electronic tach that fits the '58-'62 tach opening with a simple hookup.
ryan22 (12-08-2019)
ryan22 (12-08-2019)
Thank you for all the replies. The gauges need restored so I'm gonna pull the cluster, send the gauges out and convert the tach to electronic. I'll let ya know how it turns out.
