Anyone glassed over the front popups?
1 Post
St. Jude Donor '03-'04-'06-'08-'09
When I posted above, I was not able to see the pics due to being at work.
I take back what I said...I really like this a lot! I would like it even more if atleast the "outline" of the orginal headlight covers were still there. I just think when you "smooth it" all out, there is too much blank open space.
i would use the headlight covers as a template and make a some "flat" stock first then glass that in ...instead of trying to glass the entire opening on the car........
b
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
1 Post
Thanks Chris. By the time it gets done, I think there will be enough eye-catchers to minimize the blank look on the nose. The grills will be custom and will also be matched at the opening of the hood scoop. Trying to minimize the bling while still showing the personality (shark on steroids) of the beast. Now if I can only finish making my vision solid.
No prob...and once you get it done, I actually may be able to see it in person. I am down in Paducah every once in a while picking up sick babies at either Western Baptist or Lourdes. I am about 3 1/2 hours from you.
Cruise-In I Veteran
St. Jude Donor '03
The last time I think that kit was available was in the early 80's from Ecklers. They look good when done. But you might also go on the look out for the grill as Ecklers also produced custom grills just for this purpose that looked great. From my best memory they came in either round tube or flat fin style like would be on say a 73 Corvette. Back in the 70's a friend purchased a fiberglass 73 nose and cut it up and did some more fiberglass work to it and removed the front bumper and put that on instead. From memory I think it was an 8 in increase on the front nose. It was dang sharp.
#33
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,431 Likes
I think the Original Poster got his thread hijacked Big Time.
#34
Cruise-In I Veteran
St. Jude Donor '03
I'll take that as my cue to exit, but the entire thread has been in response to OP's original inquiry. Suggest you read post #9 and #10, take two pills and come back when you graduate from moderator academy.
