Wiper Motor Rebuild
Wiper Motor Rebuild
I was looking at some older threads and found one from "Mooser" on rebuilding the wiper motor assembly. I thought that it was a good procedure and copied the images and text and converted it to a PDF file to save on my PC.
Thought that it might be good to put on the Forum and asked Mooser if he had a problem with my doing that. He replied that it was fine as long as he was mentioned as the author. This file is his work, all I did was to convert it to a PDF file so that it can be saved on a PC.
An update was added below in entry #4.
Last edited by robertea; 05-01-2024 at 09:26 PM. Reason: they still didn't attach the PDF file.
The following 2 users liked this post by robertea:
67:72 (05-01-2024),
BigBlock77 (05-02-2024)
Received 3,174 Likes
Maybe you should add the bits down near the bottom of the original thread where it talks about the missing resistor and where it connects as well as the modern/available replacement resistor
M
M
M
