Power Brake master cylinder on a manual brake car?
![](/forums/images/ranks/3k-4k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Can you install a power brake master cylinder on a manual brake car? I am not looking to convert to power brakes. I just want a master cylinder with a larger bore.
thanks
thanks
![](/forums/images/ranks/7k-10k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
The larger bore will cause less pressure for the same pedal effort. Sure you will move more fluid but at a cost of braking power. While it will bolt in the rod might not be the same. The piston in the back of the cylinder I think is deeper with the non power brakes. Don't know this for sure.
This sounds backwards to me. Can you explain where I am wrong? If you move more fluid for the same pedal movement, then wouldn't your line pressure be higher for the same pedal movement?
![](/forums/images/ranks/4k-5k.gif)
You can use a power cylinder but your pedal effort will be a bit higher for the same system pressure. This is because the power piston is 1.125" and the manual is 1.0" in diameter. So this is one of those: Just because you can do it doesn't mean it's a good idea.
And, no, this is not backward. Has to do with piston area. Think about the PSI as pushing on both ends of the hydraulic system. The bigger the piston in either the master or the caliper(or both), the more of the "inch" there is for the PSI to push on.
![](/forums/images/ranks/2k-3k.gif)
St. Jude Donor '05-'06
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
Originally Posted by redvetracr
You can but it will be very difficult (trust me) to push the pedal.....
.....redvetracr
.....redvetracr
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
I did this as a interim step before installing the booster. I lasted about 3 weeks. The pedal was so hard it was ridiculous. Sure the brakes work but you have to really apply a continuous pressure on them to stop.
I spent $15 on a non-power master cylinder while I waited to get all the pieces I needed to install the booster and the power master cylinder.
I think I understand what you are saying, but.
I am thinking of this as a sealed system where by you are reducing the volume. With a small bore you will lower the volume by a specific amount per inch of movement. With a larger bore you lower the volume by a larger amount per inch of movement. Wouldn't this cause pressure to be greater in the system?
Now lets say you went to larger pistons in your calipers. Wouldn't you want a larger bore to compensate for the larger pistons?
So it looks like I need a smaller master cylinder bore instead of a larger one. I was ultimately looking to increase line pressure and reduce pedal effort.
Not to confuse the situation but in the Corvette section of the (older) Chevy power book they talk about a 1.250" truck master for use WITH a booster............it works
.....redvetracr
.....redvetracr
Ok, I think I have this all figured out.
By going to larger pistons in the calipers, you would require a smaller master cylinder bore to get the same line pressure to actually increase your braking. This explains why my pedal effort was more with the C5 calipers and the stock 1" master cylinder. The C5 calipers are 2 piston calipers which was throwing me off at first.
After breaking out the ol physics book and doing some calculations, it shouldn't matter if they are 2 piston floating or 4 piston fixed due to the design.
With the same line pressure and the same piston diameter the pistons will exert the same force onto the pad regardless if 2 or 4 piston. This is because the pressure pushing the piston is also pushing back on the sliding caliper applying force to the other pad.
The C5 pistons are larger than the C3 pistons meaning the C5 calipers would give more clamping power for the same line pressure.
Looks like I need to find a 7/8" master cylinder.
.....redvetracr
.....redvetracr
My '68 had a power master cylinder on it from the factory and was an original manual brake car. It had never been replaced as far as I could tell. Correct bleeder screws, correct date, correct number (for power brakes).... The power brake master is 1 1/8" bore the manual is 1" bore.
The best I can figure, it was installed by mistake or the line was short of manual cylinders so a power M/C was installed. Neither me or the previous owner ever knew different until I started the restoration.
I installed power brake booster and lines and rebuilt the master cylinder during the restoration.
[QUOTE=69autoXr]Any idea what year truck master?[/QUOT
Sure!! 74-75 20&30 series Chevy trucks, you should also know you will probably need to "slot" the mounting holes and remove the pressure reserve valve from the rear circuit.
.....redvetracr
.....redvetracr
Originally Posted by 427V8
What is the diameter of the C5 piston?
A C3 has 1.875" piston is front giving 5.519 in2 of piston area.
an equiv single piston would be 2.65" in diameter.
I also had a larger master cylinder bore on a manual car. My brakes weren't worth a darn. It took a while to figure it out. When I went to the 1 inch bore, my brakes improved a lot. I also changed from stock organic pads to HAWK HPS pads, another big improvement. Bench bleeding the calipers also made a huge improvement. This is on a 68.
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,426 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
