T5 swap into 72 Corvette
#42
Keep in mind, I ran a T5 in my Mustang for 140K miles with no issues.
Finally gave in and put a TKO in when I went to a 347 stroker and a S/C
Don't take offense, but chevy's look real good in my rear view mirror.
Hope everyone had a great new years and I'll be checking back in tomorrow when I get to work.
Richard
#44
Another thing nobody seems to talk about is that most T5s that were installed in a performance car (Mustang, Camaro, Firebird) had a torque arm hooked to tailshaft and the rear end.
I believe that many T5s are broken because of wheel hop. That will have no affect on the transmission in the Corvette application since we have the diffferential mounted solidly to the frame.
Food for thought Jeff
#46
Richard
#49
Richard
#50
Are there any ways to inspect a Ford T5 for that weak link...say if buying one out of a salvaged car? Do they slowly go bad...or just snap do to miss-use? I can get a T5 pretty cheap as a pull off.
#51
SSS:
Thanks again for coming over and answering some questions for these guys. I'm glad there are guys out there like you that are willing to help others put "ANY" 5 speed in. Afterall, isn't the main point here, just to overdrive these cars???
Richard
#52
Other than opening it up and doing a visual, I don't know but if you can wait until tomorrow, I'll check with my builders for some tips. They don't just break. It happens over time.
SSS:
Richard
SSS:
Richard
Oh I can wait for as long as it takes. I'm not buying it immediately. Thanks for the help.
#55
It was a salvage yard, I had a big fight with them over it. They swear it is a v8 unit and had a local dealership join the fight for them, but 5speed.com has it listed as a v6. It's from a 92 camaro wc.
Chris
Chris
#56
All V8 units in 1992 had a 26 spline input. If you have a 14 spline input then it is a V6. The later cars 95 and up only had T5's in 6 Cylinder models. The Tag ID program I wrote is based on Borg Warner's build records, but who knows there could be a typo! Many salvage yards also piece together transmissions. the V8 and 6 Cylinder cases are identical. So it's possible to dump V8 gears in a 6 Cylinder case.
#57
5speeds
Cool, I didn't know you existed here. It is a 26 spline, but I also have a 14 spline NWC. The thing is at Auto Zone they don't list a 14 spline camaro v6 clutch. They do list a 14 spline 11" for the astro vans though.
Chris
Chris
#58
Hey 5 Speed what do you think of the theory that the non world class is stronger since the gears don't have needle bearings and should have more strength since they are thicker? Curious what your opinion is.
Thanks SSS
Thanks SSS
#59
#60
The big issue is WC boxes have more surface area on the 1-2 synchro rings and the counter gear is supported on tapered bearings as opposed to sloppy fit drawn cup roller bearings of the NWC. The tapered bearing case has better gussets, and webbing and no longer stretches and leaks. You can also preload the countergear to keep it more stable. WC boxes also got made with better alloy gears staring in 1986. The jump from 8620 to 4314 alloys made a huge difference in strength.
My Enduro design actually makes the 3rd gear bore larger and equal to the second gear bore. It creates less stress risers on the mainshaft.
For your viewing pleasure....
http://www.5speeds.com/racing/jt5rc.html
