How do you adjust the TH400 kick down switch?
![](/forums/images/ranks/5k-6k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Since redoing my interior,(thick insulation) my gas pedal linkage no longer contacts the switch. Is there a way to adjust the switch? There is a bolt in the center of the bracket but two tabs holding it in its position, doesn't look like there is adjustment.
I thought about making a spacer and putting it on the shaft on the switch but I need a LOT of gap taken out. I want it to kick down with about 3/4 throttle. At WOT the linkage is about a 1/2" away from contacting the shaft on the switch.
I did a search but found nothing....
Thanks in advance guys.
![](/forums/images/ranks/11k.gif)
General rule is adjust both at WOT. Wire open, or have a friend hold the throttle wide open. Get under the car, and adjust the detent so it's pushed in full matching the throttle. That's it.
![](/forums/images/ranks/4k-5k.gif)
Just did mine last summer.......I removed the bracket and slightly bent it so that when you have full throttle, it pushes the switch the 1/2" it needs. A little trial and error,and takes more time, but is better than using a spacer.
Thanks C3, I will pull the bracket off and see what I can do. It used to work with my old carpet but I put so much dynamat under it, it seems to kill the travel. I got the carb going WOT but the pedal linkage is far from the switch... I will try to bend it some.
DB, these don't have the cables like you are talking about, its got a little switch above the gas pedal that the linkage hits...
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,997 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
The TH400 kickdown switch sets itself automatically the first time the switch is depressed. To re-set it, depress the plunger fully, and then let it flick off your fingernail so it pops up forcefully. This will bring the plunger up to its pre-set fully extended position. Then, simply press the gas pedal to the floor. This will depress the switch to its correctly adjusted position.
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
JavaJolt78 (07-29-2021)
Thanks Lars, I will try that but to be honest with you, it doesnt even look close to touching when the pedal is to the . Its like the shaft on the switch(plunger?) travels more up and down and less front to rear and I need it to be further forward. I will try your adjustment in a few mins and report back. THANKS
LARS, I reset the switch like you said, the gas pedal linkage does contact the switch at WOT but it seems to push the switch to the point where the linkage stops, then when I release the gas, the linkage returns and the switch stays in the same spot. When I mash the gas again it just BARELY rubs the plunger not really moving the switch at all. Its almost like I need the switch to stay in its fully extended position for normal operation. Maybe my switch is jacked?
Well I thought I had it fixed but no cigar. It seems to be making contact with the plunger but not enough I guess. Its moving it some but its still not kicking down. I recently fixed the wire connectors at the solinoid so I guess I need to check the switch for power etc...make sure its working because its not kicking down. It was working back a few months ago so I know the solinoid is working.
C3Stroker, how well does your kick down work with the stall converter?
RowdyMT (07-29-2021)
![](/forums/images/ranks/500-1000.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
I have a 75 L-82 all stock. I'm not sure which transmission I have (350 or 400) but I was under the impression that my kickdown work on vacuum and that I did not have a kickdown switch.
AM I wrong? Do I have one?
hey i thinki have the same problem.......idk i took my car to a transmission shop the other week cause my car seems to be loosing alot of its power and he said my kickdown switch was bad or somthing and need to be replaced......it took him like 3 days and he told me hed rebulit it for like 250bucks.....i was like screw that and went lookin for one on jegs and summit but that was a no go......was this dude pullin my leg or would i need to replace it? im bout to say screw it and just do a new transmission maybe one with an over drive since mines a 3spd automatic.......idk
![](/forums/images/ranks/3k-4k.gif)
St. Jude Donor '11-'12-'13,'19-'20
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
Well, after following LARS directions, my gas pedal linkage rod would still not hit the switch correctly. I could reset the switch, then hit the gas and it would contact the switch to the area where the travel would stop. Once I released the gas pedal, the switch would stay in the same position and hitting the throttle once again, it would not contact the switch or would barely kiss it. I think my switch has a bad spot in its travel. NO doubt after 138k miles. It seems to have a dead spot in the ratcheting mechanism RIGHT where the pedal rod touches.
SOOOO, I made a little "spacer" out of a couple pieces of fuel hose and slid it on the plunger. Now when I kick it about 90%, it kicks down every time... I did it about 20 times today...LOL its funny, when it kicks down into 1st from a 30 roll, it almost upshifts immediatly at 4200 rpms...LOL
The kick down feature is definetly MUCH smoother then just pulling the shifter down to 1st and trying to time it right.
I know I did a bubba but I am not sure you can even GET a kick down switch, not to mention replacing it would be a bastard. I am just making mine work in a different zone in its travel and it is working good for now.
![](/forums/images/ranks/100-500.gif)
The TH400 kickdown switch sets itself automatically the first time the switch is depressed. To re-set it, depress the plunger fully, and then let it flick off your fingernail so it pops up forcefully. This will bring the plunger up to its pre-set fully extended position. Then, simply press the gas pedal to the floor. This will depress the switch to its correctly adjusted position.![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
doorgunner (07-28-2021)
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,431 Likes
