Seat Belts (1972)
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I am looking to get my 72 past NJ inspection.
My shoulder harnesses are missing the end clips, AND my lap belts to not extend or retract.
Do ALL lap belts extend or retract?
Is this someti8ng as simple as removing the retracter mechanism, spraying with lubricant and WHALA? or a bigger issue???
Any suggestions?
The belt DOES fit me almost perfectly so I have no real issue, since I am the only one that SHOULD be driving it anyway- JUSTY FOR INSPECTION!
Does anyone have info where I can send my seat belts and get slightly overhauled to work properly?
New end clips? retracteors reworked?
Would I be better off buying a set of working replacements from (ebay or Corvette Central and selling mine?
Does it make sense?
I would like the Shoulder Harness and lap belts to work.
THANKS
Any suggestions?
Does it make sense?
THANKS
![](/forums/images/ranks/3k-4k.gif)
to get them refurbished there is a place called "snake oil" or some variation of that... I have seen it in corvette fever and heard it once or twice on here... I'll try to google it and see what it pops up... as for the inspection I really don't know... we don't have those here in Arkansas... lucky me huh?
hth
Sully
hth
Sully
![](/forums/images/ranks/7k-10k.gif)
Snakeoyl is quite expensive. They do excellent work and the ycome back like brand new but they are $$$. Yes the 72s should retract. Chances are the retracters are rusted up and need to be replaced. You can get a cheaper set of replacement belts that work just fine. If you are not NCRS these will work good. Another alternative is a set of Camaro rear belts. These are a 3 point system, give you the shoulder harness along with the lap belts. This is what I have in mine and they are a real nice cheap alternative. Cost about 50 bucks from a boneyard. I also have a set of lap belts for my 72 that Snakeoyl has redone but they are quite expensive.
OH!
I think I will take out my lap belts retractors and see if spraying some lubricant can get them freed up a bit.
If not- Looks like I will add a non original type for now. for those prices...
![EEK!](https://www.corvetteforum.com/forums/images/smilies/eek6.gif)
![](/forums/images/ranks/4k-5k.gif)
I replaced mine with late model F-body belts I got off Ebay for $8 including shipping. They need to come out of the rear seats of a coupe but they fit great and work even better.
![](http://hometown.aol.com/bmclau5079/images/im001176.jpg)
seatbelt install
seatbelt install
Several of us have done this camaro seat belt install. I have them in my 70 convertible and would not go back. I modded my seats to make the belts pass through. If your seats do not have pass through, like Redwingvette, you can just route the belt around the seat and it works just as easily.
Here is the thread I started when I did my pass through.
If you want to keep the original belts that clip the shoulder harness to the lap belt at the latch, I think you have to have them redone (I couldn't find replacements like this). I took mine out that were frozen solid with rust, unwound them all the way, washed the belts with a pressure washer, dried them thoroughly in the sun, scraped off a layer of corrosion, and then worked them in and out with a ton of silicone spray lubricant for a good long time until all the corrosion worked it's way out of the mechanism (the friction between the plastic spool and and the metal housing takes the longest time to start working, as this controls the inertia latching of the belt), and they work good as new now.
-=Boston!=-
P.S. Resist the urge to pry off the plastic end cap with the spring inside. It's quite a project to get back together. Ask me how I know.
-=Boston!=-
-=Boston!=-
-=Boston!=-
I removed the seats and the plastic covering over the seatbelt retractor assembly.
WOW was it rusted.
Almost a total loss.
Seems like I will definately be using the F-Body belts I am purchasing.
