A Challange
![](/forums/images/ranks/4k-5k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Every thing was rebuilt except for the half shafts. But they do have new u-joints and they are good at this time. I intend to have them ballanced at this time. Should have done it prior to assembly.
I should mention that this car has less than 300 miles on it since the restoration. And the rear end has approx 320 miles on it. The distance from the rear end shop to home is approx. 20 miles.
Is it poss that I didn't break the rear end in properly??
I now have the cover off.... The ring gear teeth are shiney accross the entire surface of the teeth. When I turn the side yolks I can hear a scrubbing sound and I have to have someone hold the case in order to turn the yolks. Seems like a lot of resistance... Is this normal???
Well.... I took the carrier out and the bearing races have kind of a wear pattern to them. You can see where the rollers have been riding on the race to where the race looks polished where the rollers DO NOT touch. Where they DO make contact with the races the look is that of brushed steel.
Am I correct in assuming that these bearings have been contaminated and the pattern on the races is a result of that?
There is no discoloration of any parts, as if they took too much heat.
![Big Ears](https://www.corvetteforum.com/forums/images/smilies/bigear.gif)
Upon further investigation, I find that the carrier appears to have been shimmed too tight, thus putting excessive pressure on the bearings.
also I see that the head for the pin that secures the thrust pin is sheared off and I cant find it anywhere. No excessive metal in the housing so I believe that the head was broken off on assembly, and just left that way. Also now that the carrier is out and I can also tell that the pinion is too tight.
Not bad for $1400.00 right
Oh did I mention that I forgot my old ring and pinion at the shop for a month due to the fact that I was absorbed in the resto. When I go back they tell me that it is my fault for not taking the old parts with me when I picked the car up.
Oh well shame on me.
I will say this....Even though this place came highly recommended...I will stay away and I suggest others do the same.
The Ring and Pinion Shop on Groesbeck just south of 16 mile road in S/E/ MI. BUYER BEWARE!!!!!!
![LOL](https://www.corvetteforum.com/forums/images/smilies/lol.gif)
![](/forums/images/ranks/7k-10k.gif)
Dang -Sorry to hear you found so much inside but at least your diagnosis was on the money.Do you have any recorse with these guys-will they stand behind their work?
The problem is that I had the rear re built two years ago after I received the car. Then I did the resto and I figure if thew wouldn't give me my gear set back I don't expect them to warranty work that was done two years ago.
Maybe I should Judge Judy them.
Think I may have a case???
Any lawyers out there???
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
