Body mounts replaced with pics!
Old 03-22-2009, 02:19 PM
  #41
LIQUIDDRAGON
LIQUIDDRAGON's Avatar
this is an awsome thread thank you for posting this im all excited and i think i will do mine this summer now
LIQUIDDRAGON is offline
Old 03-22-2009, 08:08 PM
  #42
Kim72
Kim72's Avatar
Rudolph
Thanks for this thread. Very informative. I, like others here, need to do this on my 72 but have been putting it off. I have all the materials but lack the stones to get to it. I worry about cracking the body and such.
Some questions if I may:
- Great pictures on lifting the body with a 2x6. Is this a two person job?? How is the nose lifted when one side of the body is coming up?? How did you support it?? I have some road rash cracks as it is and definately don't need any more.
- Did you use grade 8 bolts?? Is this strength required??
- Is there a torc spec for these bolts??
Kim72 is offline
Old 03-23-2009, 12:40 AM
  #43
rudolph schenker
Support Corvetteforum!
rudolph schenker's Avatar
Originally Posted by Kim72
Rudolph
My son helped me. It goes much better with two people. I'm not familiar with the nose on the 72, it is probably different than my 82 on how it attaches to the front bumper support. I wish I could be more helpful in that regard.
I used grade 8 bolts. They came from Zip Corvette as a kit. I also bought some grade 8 bolts which were slightly longer for the # 4 and # 5 mounts. The kit was about 150.00
http://www.zip-corvette.com/Zip/prod...DD986A8438E19C
I could not find any torque specs. So I used my air ratchet to about 45 ft/lbs then a hand torque wrench set to 75ft/lbs (just guessed). I'm sure there are some more knowledgeable people on this than me.
When you raise one side at a time, just go very slow and watch/listen to make sure nothing is cracking, breaking, pulling etc. Remember you only need to raise it about 3-4 inches to change the cushion.
rudolph schenker is offline
Old 03-23-2009, 03:46 AM
  #44
cajos
cajos's Avatar
The write up on http://www.europeancorvette.com/html...eplacement.htm is great! I used it on my 72. Double check all frame to body attachments. I personally forgot a front bumper brace, luckily no damage.
cajos is offline
Old 03-23-2009, 10:54 AM
  #45
RATT7
RATT7's Avatar
Great tech thread ! Thanks for the pics it will be helpfull for future ref.
RATT7 is offline
Old 03-25-2009, 04:35 PM
  #46
Grumpy 427
Grumpy 427's Avatar
Ok so the body has to come of the frame then in order to get the mounts on a 1980-82 vette? I cant seem to get in to get at any of them?
Grumpy 427 is offline
Old 03-25-2009, 05:18 PM
  #47
TMRCIN
TMRCIN's Avatar
Were you really just a few fuel lines and some wiring from a body off? I have been toying with removing my 68'.
TMRCIN is offline
Old 03-25-2009, 05:51 PM
  #48
Grumpy 427
Grumpy 427's Avatar
once the motor comes out, i might as well sepperate the body from the frame. Everything else is out of the car.
Old 03-25-2009, 08:02 PM
  #49
Grumpy 427
Grumpy 427's Avatar
Ok how do you get this one out? its slipping now so i guess the nut broke loose?
Old 03-25-2009, 08:33 PM
  #50
redwingvette
redwingvette's Avatar
You will have to cut the head off and pull the rest out after you get the body up in the air. The nut is held by two flanges that have bent enough to allow the nut to spin.
redwingvette is offline
Old 03-25-2009, 08:44 PM
  #51
Grumpy 427
Grumpy 427's Avatar
Ok so then what do you do to get the nut out of the frame? How do you put another nut back in it? How high does the body have to come off in order to get at it?
Old 03-25-2009, 11:39 PM
  #52
Snowman
Snowman's Avatar
CI 1-2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '03-'04-'05-'06-'07-'08-'09
Rudolph,
First great work yourself on your own car. Thank you also for the care you took to document and share everything you accomplished. Picture is worth 1000 words and all that.
You are a good man. Thank you.
Doug
Snowman is offline
Old 03-26-2009, 04:23 PM
  #53
rudolph schenker
Originally Posted by Snowman
Rudolph,
Doug
Thanks!
Old 03-26-2009, 04:32 PM
  #54
wcsinx
wcsinx's Avatar
Yes
Look at this pic of Rudolph's...
It's a captive nut that you have now "liberated". Once you lift the body, you'll be able to get a wrench on the nut. But in order to fix it, you're in for a bit of welding.
wcsinx is offline
Old 03-26-2009, 08:49 PM
  #55
Grumpy 427
Grumpy 427's Avatar
Oh great now i need to find somebody with portable welder. ****.
Old 03-26-2009, 09:18 PM
  #56
RippoDippo
RippoDippo's Avatar
Sinking a Hook in this thread!
RippoDippo is offline
Old 03-26-2009, 09:25 PM
  #57
Fastguy
Fastguy's Avatar
St. Jude Donor '03-'05
If your car is rusty, more drastic measures may have to be taken.
Also, you may want to invest in a new bracket for the rear mount if yours is rusted.
Fastguy is offline
To Body mounts replaced with pics!
Old 03-27-2009, 03:14 PM
  #58
Grumpy 427
Grumpy 427's Avatar
The pictures dont give the whole story? How high off the frame do you need or can you lift the body. how do you get your hands in there to get the mounts off? Not a lot of room to work here. i get the feeling that the body will need to be completely lifted to this properly.
Old 03-27-2009, 03:48 PM
  #59
rudolph schenker
Grumpy, I lifted the body 4 inches and was able to easily change the mounts. Do only one side at a time. Remember to leave the #2 and # 3 mounts in when doing the passenger side and #6, #7 when doing the driver side ( this will help maintain body alignment). If you stripped the cage nuts in either 2,3 or the 6,7 places I'm afraid you will need to do some welding to repair them. In that case you may need to completely lift the body. Hopefully some one could chime in who has had to do this repair.
Old 03-27-2009, 07:24 PM
  #60
Grumpy 427
Grumpy 427's Avatar
Are there 2 more mounts under the nose somewhere that need to be removed as well before i attempt to lift the body? i downloaded the install instructions today from Ecklers, and they dont show any nose mounts? I think i will wait till i get the hood and the motor out of the car before i go any further.
Quick Reply: Body mounts replaced with pics!
