Running an XFI camshaft on a carburated engine?
![](/forums/images/ranks/5k-6k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I've been offered a comp XFI (Xtreme Fuel Injected) camshaft from a forum member for free to use in my carburated 350. What are the downsides to doing this? Will it run at all? or is there only a slight decrease in performance. The specs are listed below:
Intake Exhaust
Gross valve lift .499 .493
Duration @ .006 tappet lift 260 272
Open Close
Valve timing @ .006 Int. 21 btdc 59 abdc
Exh. 73 bbdc 19 atdc
Cam installed @ 109.0 Intake center line
Intake Exhaust
Duration @ .050 216 223
Lobe lift .3120 .3080
Lobe separation 113.0
I can't imagine why it wouldn't work. The lobe separation is a little large but that should help smooth out the torque curve right? everything else looks normal though (to my completely untrained eye).
Anyone run a FI camshaft on a carburated setup?
thanks
Intake Exhaust
Open Close
Intake Exhaust
thanks
The XFI series is IMHO a very good line of cams, and should do just fine with a carb, as long as the selection otherwise matches the application (heads, CR, your purposes...). The wider 113* LSA than many CompCams Chevy grinds (110* being fairly common) may cost a touch of peak torque/power vs. what that same cam might produce with a narrower LSA, but you'll pick up some bonuses such as a wider power band, better idle quality and increased vacuum. IF this all sounds good, go for it.
Of course, you've left out some important details (particularly your current basic engine specs), so this observation is highly speculative.
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
TSW
TSW
TSW
TSW
![](/forums/images/ranks/3k-4k.gif)
If this XFI cam was from a newer "roller motor" then it will not work in your older non roller engine. The nose of the cam is different and must be mated to the matching cam timing chain gear which is designed to only fit a roller block.
![](/forums/images/ranks/7k-10k.gif)
TSW
TSW
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
Cruise-In VII Veteran
St. Jude Donor '07
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
FI cams will usually have a 220 duration at .050 for a stable MAP signal. Not a bad thing to have since it will help with vacuum. Motor will be easier to drive with an automatic also.
