Correct Carb for 1970 LS7 454 motor
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Purchased a 1972 LS7 454 motor to put in my 1972 Corvette. My understanding is this motor was never put in a Corvette, but sold as a crate motor. I'm in need of the correct Holley carb that would have been sold with the motor at that time. The following is what I beleive to be correct.
Holley model 4150 850cfm dual pump
Carb list# 4493
Part# 3967487
R-4493A
Primary 6203
Secondary 6207
Center pivot float
If this 4150 base was used on different size carbs, would it be safe to say one could be built from the 4150 foundation if a complete carb is going to be a tuff find?
Regards,
Lee
Carb list# 4493
Part# 3967487
R-4493A
Primary 6203
Secondary 6207
Center pivot float
Regards,
Lee
![](/forums/images/ranks/5k-6k.gif)
LS7 was supposed to be a 70 motor option but never happened, a few motors sold over counter (crate) and put in cars. never an option for 71 or 72. motors were offered over counter by dealers however.
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
![](/forums/images/ranks/7k-10k.gif)
![](/forums/images/ranks/4k-5k.gif)
![](/forums/images/ranks/100-500.gif)
When I bought my LS-7 crate engine new in the early 70's, it did not come with a carb or an intake. I don't think that it ever did. It was a bare long block. You supplied all the accessories; Intake, carb, water pump, exhaust etc. What you read about the carb size and intake, is what was proposed, or recommended, if indeed they did put it in a production car. I used a Holley 850 double pumper, and an Edelbrock TM-1 single plane intake, and it ran quite well. At the RPM that it would turn, I'm sure that you could get by with a bigger flowing carb, and a more up to date single plane intake, and it would run even better than mine did. Good luck trying to find gas to use with that 12.5 to 1 compression ratio, unless you want to use race gas. That's why I retired mine to a corner of my garage.
427Hotrod (04-25-2024)
![](/forums/images/ranks/2k-3k.gif)
I inherited an LS7 and I think a 850 holley is what was used if I am correct. Ditto to the above comment about the compression, I wanted to install this but was reminded several times the HP would drop with a lower streetable pump gas compression.
![](/forums/images/ranks/3k-4k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
That sure would have been sweet had they offered the LS7 in 70.
I seem to remember reading pre releases in the car mags of the day...460hp...would have eclipsed the L88's and ZL1 vette ? Guess we will never know now
LS7`s were neither supplied with carbs or distributors. They came as a long-block with valve covers, timing cover and oil pan.....Also absent was the intake and fuel pump...I have the engine in a 1968 Camaro and used a L88 intake with a 850 4 bore Holley...A 950 3 bore was also compatible with the open plenum L88 intake...I would use the 850 and the E Bay HEI with the tach drive. I used a 75 passenger distributor as a tach drive distributor was not necessary
How fast? 11.40`s at 120+
Yep that was the advertisement, I think it was way north of 500 hp in reality. Be curious to do some research. I am sure an engine like that with I think the big rectangular port heads and 12.25/.5:1 compression would bound to put out big numbers on the Dyno.
They actually did come with a carb and intake 850 dp and dual plane intake #3933163 it was a winters foundry forging that what the one i have came with I still have the motor in my garage.
Received 1,948 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
JIM
![](/forums/images/ranks/500-1000.gif)
This thread is from 2009 but i will throw this out there. i have a old hot rod magazine from the 80's with an article they did of John Lingenfelter where he purchased one of these LS7 crate engines and did some testing. out of the crate he dropped the oil pan just to clean out and metal shavings then put it in the dyno - 489hp. then he tore it down and blue printed it and put it back together with all the same parts except he dropped the compression to 9:1 , back on the dyno - 510hp. then he changed the cam to a comp 305h hyd flat tappet and did some porting and his final dyno run it made 567hp. this is all off the top of my head but i know the hp numbers are correct.
Pat
Pat
