Small block Hybrid LS engine.
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Has anyone had any experience or seen anyone use this motor for a C3 or anything else. http://www.theengineshop.com/product...ron-block.html
![](/forums/images/ranks/4k-5k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
I have not heard of anyone using this block before, but for the $ they are asking you can probably find a complete used LS engine with accessories, harness and ECU. Byt the time you built a complete engine with that block you could probably buy a LS crate engine for less $, and have the advantage of an aluminum block.
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
Rick B.
Rick B.
![](/forums/images/ranks/7k-10k.gif)
Iron block is much stronger / durable than OEM aluminum LS block, especially with the splayed billet caps, depends on how much HP you want to make.
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
im going to add this that your better of going BB or GEN I, III, IV iron block over this. because it looks to be a lot of parts that requre an lot of $$.
its ment 4 peeps who have all the Gen I/II stuff and want ls heads
Its only going to be making 500h-600p.. I dont want much more then that. To be honest, its more about doing something different. Its a fun way to do 427 naturally aspirated, and the design is a bit off the wall. Here is an article on it. Higher than that, traction seems to be not enough.
http://www.superchevy.com/technical/...ine/index.html
Rick B.
Cruising
On page 3 of that article, "Quote.... the engine produced an eye-opening 629 hp/579-lb-ft result. That's about 70 hp more than one of World's regular Motown small-block 427 engines and about 15 horses more than their typical Warhawk LS combos."
WOW!!! 630 HP
![EEK!](https://www.corvetteforum.com/forums/images/smilies/eek6.gif)
---Bill.
![](/forums/images/ranks/5k-6k.gif)
It's a dollars and sense thing - balance the cost of that block vs. the cost of all the pieces requried to make an LS fit into a C3, sans headers. IMHO, it's at best a wash at this point - a few years back finding mounts and making stuff fit was expen$ive, but it's getting easier and cheaper all the time. IMHO, for $3K it's not a great deal with ready availability of swap kits and prices on LS junk engines (especially iron ones) and aftermarket crates. Scoggin Dickey will sell you a crate shortblock 427 for around 5K!
I wouldn't lose any sleep over the power capabilities of the LS aluminum block. Plenty of C5 guys are getting mondo power out of them...some near 1000 FWHP. There's a guy locally that put down about 700HP at the rear wheels at a dyno day I put together with an engine built by 'tjwong' on the board. Tom can answer your questions in detail about what can be done with the LS...but 500-600 FWHP is pretty much "off the shelf" with an LS these days. Recall that a stock LS6 makes 405+ at the flywheel![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
Take a look at the main bearing web in an LS - strength is not an issue here.
![](http://www.maxchevy.com/tech/2008/iii_12-lsprimer/MC-0812-LS-2.jpg)
I understand there are issues with pin oiling if you get up into really big numbers, which is typically addressed by "squirters" that direct oil at the pin as well as a few other tricks. Forced induction to crazed levels can also be an issue with the pressed-in sleeves. But a GOOD shop isn't going to have any problem with this stuff.
My buddy took me to a corner of his shop and showed me a bunch of blowed up aluminum LS blocks when I was thinking about going that route, so I went a different direction and used an iron block.
Told me straight out guys put too much power thru them and they won't handle it. I don't make this stuff up just report it.
![LOL](https://www.corvetteforum.com/forums/images/smilies/lol.gif)
http://www.chevyhiperformance.com/te...ild/index.html
Should be a nice little LS motor.![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
But you better have some deep pockets.
![](/forums/images/ranks/1k-2k.gif)
I almost bought one of these motors, you need a sb2 style camshaft or ls ,then you need the adapters plates etc. for the top end .throw some ls7 heads 680hp .
What Ive read about the LS engines were the oil pump failures.
and thats when your making 600hp +.
