Printed Circuit Boards Question
![](/forums/images/ranks/3k-4k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Is it possible to get a one piece printed circuit board for both the speedometer and tachometer and one for the guage cluster. I am aware of the printed circuit board for just the tach. If so where can I find these?
![](/forums/images/ranks/2k-3k.gif)
I have never seen them seperate. One board does the speedo and tach together and a second does the center gage cluster. They are very easy to replace and money well spent. Make sure your plug contacts are clean and that they provide tension. If they ar a little loose fitting just tweek them out a little. I clean them up with a little fine sand paper.
