hood clearance question
![](/forums/images/ranks/5k-6k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_navy.png)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Stock hood. Looks just like mine. The Typhoon is a Performer RPM clone. You will not be able to use the stock air cleaner. If you use a drop base aircleaner like the Moroso I showed above, you will be able to fit a 3" tall filter element with adequate hood clearance.
