Has anyone ever tried Leaded Gas?
![](/forums/images/ranks/7k-10k.gif)
![](/forums/images/ranks/5k-6k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Recall when car's were switching to unleaded fuel, regular leaded was still around for awhile. Was cheaper and a few point's higher, so many pulled the cat's and punched out the filler neck's to use it. With 93 unleaded common in my area now, really don't give it much thought. Some state's kept leaded regular around for year's. Was on a ski trip in Taos New Mexico in the mid 90's, and they still had it availible. Not sure what for, but maybe farm equipment.
![](/forums/images/ranks/2k-3k.gif)
The lead was removed for emission reasons. Then the valve seat issue was discovered. Seat erosion was the result. Cure was the hardened seats. Small adhesions of the valve seat to the valve face took place and the valve upon lifting pulled the adhesions from the seat. In time the seat material removed will let the exhaust valve lower into the roof of the combustion chamber. I've seen them, under normal driving use, with the entire exhaust valve below the roof of the chamber.
Only takes place , for the most part, with the exhaust valve. Normally more pronounced with the two center exhaust valves do to the heat developed by the exhaust being next to each other.
![](/forums/images/ranks/1k-2k.gif)
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
![](/forums/images/ranks/3k-4k.gif)
![](/forums/images/ranks/11k.gif)
My memory may not be correct, but, I think I remember unleaded becoming popular in '75 because it was necessary for the catalytic converter. Prior to that the only unleaded I remember was Amoco Hi- Test. I can't imagine all the manufacturers putting in hardened seats in '71 because of one grade of one company's gasoline. Although, I do remember reading somewhere that Amoco unleaded users may have needed more valve jobs.
25% more crude consumed for 40 years, that's a decades worth of totally un necessary crude consumed, then we wonder why prices went up.....
thanks green weenies, bunch of idiots....spring off from Ralph Nader....
![Toe Tap](https://www.corvetteforum.com/forums/images/smilies/toetap05.gif)
![Ack!](https://www.corvetteforum.com/forums/images/smilies/ack2.gif)
![Smash](https://www.corvetteforum.com/forums/images/smilies/smash.gif)
![No No](https://www.corvetteforum.com/forums/images/smilies/nono.gif)
Lead was a good, cheap way to increase the octane rating of fuel so we could run higher compression ratios. Back when it was available, you would pay less for leaded, and it would have a higher octane rating than the unleaded. I didn't put it in my '77 Trans Am because it had a cat, but I did fill my parents' Corvette with it when I drove that.
And once again, I'll ask for proof of any Corvette heads that have suffered valve recession due to lack of lead. The claim that 'they've all been modified' is false.
then me noting a solid 15% reduction in fuel economy.....I used to drive 20 miles one way to work, that reduction HURT, especially with all the price increases....cut into date money...
and it was not JUST ME that noted a similar reduction in economy, friends and even my father noted the same thing.....
so do the math....25% more crude consumed/mile traveled/gallon used.....
lovely thought, eh??
eff the weenies forever,
and what's all this ill health supposedly brought on my leaded gas..?? see pilots and old gas station mechanics falling over right and left ?? seen it back then?? or something fed a lab rat to abject overdose the the rat finally dies, so they claim it's harmful???
![Crazy](https://www.corvetteforum.com/forums/images/smilies/crazy.gif)
![Rolleyes](https://www.corvetteforum.com/forums/images/smilies/rolleyes5.gif)
![EEK!](https://www.corvetteforum.com/forums/images/smilies/eek6.gif)
I probably still have sbc heads from the early 70s era laying around the shop someplace that have eroded exhaust seats. Whether they were from an Impala or a Corvette is inconsequential. A casting number is a casting number. Valve sizes were different among the same cast number, but the heads themselves were the same. I've taken 461s and 461x's out of grocery getters in those days. Back then it wasn't uncommon to find a four bolt 300 hp sbc in a station wagon.
When you could order your car the way YOU wanted it then there were all kinds of possible combinations.
The last set of 461s I put seats in were so eroded that I was reluctant to cut it for inserts. Without sonic test results I would have probably passed on the job.
I have a publication from an engine builder organization I belong to that addressed this very issue. If I can find it I'll get some of the information from the article.
#33
There's a reason they changed the size of the filler hole when catalytic convertors were introduced...a simple deterrent to leaded fuel usage. The lead coats the matrix in the convertor, keeping the catalyst from contact with the exhaust stream rendering it ineffective. If you run a convertor equipped car on leaded fuel for long enough, the matrix may plug solid and cause extreme back pressure, with predictable deleterious effect on your car's performance. Is no one else here aged enough to remember this transition?
#34
Corvette engines never ran hard enough for long enough to do such damage. But the myth lives on...........
#35
Maybe that was true in 1973 when the refineries were still adapting to unleaded. Hardly true today after 40 years of improvements.
#36
The other pump was labeled Hi-test. All the hot-rodders that didn't want (or need) to travel to the far off Sunoco station for 260 said, "Fill 'er up with Hi-test." I don't know how much octane that was either. But I can remember the last price before they tore them and the steel underground tanks out...32.9 cents!
Which makes me wonder why no other retail commodity is priced in tenths of a cent??
![Confused](https://www.corvetteforum.com/forums/images/smilies/confused5.gif)
#38
#39
Maybe since the exhaust is up int the air (so to speak) it will have a greater chance of dispersing before people come in contact with it.
BTW, I did find info on that NASCAR banned leaded fuel in '08 after crew members tested positive for elevated levels of lead in their blood.
#40
The cost of modifying existing engines to run on low octane gas is horrendous, frequently exceeding the value of the aircraft itself never mind having to accept greatly reduced power output.
Since the market share of avgas is tiny (0.5%) as compared to cars, there's not much to be gained by forcing it out of production.
