Installing 454(496) into 77 L-82 Th400 Car
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Thanks in advance, I have searched this forum for weeks and cannot seem to locate any simple straight answers to the following questions.
77 L82 Car with AC
No Smog pump
Power steering = yes
Alternator
Water pump
Hooker Super Comp Headers
Electric Fan/ pusher in front of condensor.
Aluminum radiator.
1. What exactly is needed to install pully system, even without AC for the time being as this is only a nice weather toy.
pullies?
brackets?
idlers?
Or if anyone can reccomend an aftermarket setup that can use a Sanden AC compressor etc.
2. Are there any differences in the power steering setup, ram, control valve etc? As far as I can tell it all appears the same.
The small block motor mounts willl work, I set the motor in the car and seemed fine.
77 L82 Car with AC
No Smog pump
Alternator
Water pump
Aluminum radiator.
pullies?
brackets?
idlers?
![](/forums/images/ranks/3k-4k.gif)
