The start of my 454 swap
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Hey scrappy76, It's your car , do as you wish.. You won't be happy otherwise. I've heard all the negatives and they have there points but in the end make yourself HAPPY.. Good Luck
![Rock](https://www.corvetteforum.com/forums/images/smilies/rock.gif)
![](/forums/images/ranks/2k-3k.gif)
UPDATE . Found another 454. This one is complete from the fan blade to the flywheel. It even has the starter, and only has 57,000 orginal mile on it. I will freshen up and change what is needed to include the oil pan to fit. I have also got ahold of a 4 core radiator. Will get some pics up soon.
I have put a 92-ish Gen-V 454 in my 71, and can say with some assurance that the Burban/truck oil pan on this motor hangs WAY too low, so I am interested in what you use for a pan on your motor.
My motor is also a low mile take-out. Installed for now, lost direction on the project (for 4-5 years!), but just want to get it running well enough so I don't have to push it. I hate pushing cars...
Good luck, gonna be watching
Tom
Tom
I plan on doing a late model 97' 454 vortec swap in the future. I will tweak it a bit but nothing to crazy,my car is a street car.
Going to bore it 60 over with a 4.25" stroke crank,6.385 rods and some forged pistons to get around 10:1 comp ratio. A set of decent heads,hopefully aluminum. Comp cams computer controlled cam 01-419-8 and bigger injectors,computer reflash etc.Probely will also need bigger throttle body.
It should have some decent grunt and still be a nice running streetable engine.
Engine i have is the same as this one,
Tom
Tom
My 454 swap worked fine with the truck pulleys, and Alt mounts. Needs rewiring though.
Non power steering though, but you may want to check first. The stock style pulleys are expensive.
Maybe my oil pan wasn't stock, but it fit fine as well.
It did run hot with the radiator, but with a pusher fan it now stays cool.
Fun project all they way!
Anyways, I did buy it today and will start cleaning it up. I will add pics of it tomorrow.
Only thing I would suggest is a mild performance cam while its out of the vette, much easier to do if you are tearing into it too. Search peanut port 454 builds, and you will see small cams make good hp and huge torque with just headers and carb. If you are an auto this would be a real good engine after bolt on mods.
![](/forums/images/ranks/5k-6k.gif)
Anything new on the progress of this swap?
![Lurk](https://www.corvetteforum.com/forums/images/smilies/lurk5.gif)
![](/forums/images/ranks/1k-2k.gif)
Small block radiator will cool that engine. I have a 496 in my 81 with the SB radiator, runs about 200°f in mid ninty degree weather. I would put at least a rv type cam in it with a new timing chain. That cam will boost torque and not empty your wallet. While the pan is off I would at least inspect the oil pump also.
#33
#34
I have the engine cleaned and painted. I have replaced the stock valve covers and gaskets. I just ordered a short water pump and fuel pump which I will put on this week. I also am getting the pulleys and brackets needed. Its slowly getting there, remember this is a budget build, dont have alot of coin.
#35
![](http://forums.corvetteforum.com/picture.php?albumid=9859&pictureid=52384)
#36
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
#37
Summit has pulleys that will fit.
#38
Also you need to use the tall mounts to clear the crank pulley/crossmember. I used the short ones because of the underdriven crank pulley on my motor was small in diameter and I needed hood clearance.
#39
Like I said, Summit has pulleys that will work.
#40
i have 2 new, never used bbc cams for sale. $50.00 +shipping each.
one is a comp cam hyd. i dont remember the specs. have to check. but i think it's somewhere around 220@.050 range and the other is a summit brand 540/540 238/248@.050 hyd.
