6.75" or 8" harmonic balancer
![](/forums/images/ranks/2k-3k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
looking at summit they have two OD listed. what are the differences ?
http://www.summitracing.com/parts/SUM-161350/
http://www.summitracing.com/parts/SUM-161358/
they look the same to me ?
so did the L-46 350/350
so if you have an L-82 you need 8" otherwise the 6.75"
![](/forums/images/ranks/5k-6k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_navy.png)
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
what Really matters is which timing tab indicator You have on Your motor.
It should lay very close to damper's outer edge.
If so, measure Your damper diameter & replace w/ same size.
and complete your profile to include an approximate geographic location.
