Lessons learned from Motor Oil Wear Testing
![](/forums/images/ranks/3k-4k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
My supposition {and I will clearly state that it is only my supposition} is that the problem of wiping cam lobes lies with the cam manufacturers who are using poor quality steel and or poor quality heat treating of that steel. I highly doubt that the oil is the deciding factor in this whole 'boondoggle'. [...just sayin'....] ![Toe Tap](https://www.corvetteforum.com/forums/images/smilies/toetap05.gif)
![](/forums/images/ranks/5k-6k.gif)
For a flat-tappet cam, the fore-and aft movement isn't what I'd call a precision fit...someone would have to massively screw up the rear cam plug install to cause an issue, and there really isn't a lot of room to leave it too far out. I wouldn't personally see any need to test lifter rotation - I never have.
I wouldn't personally see an issue transplanting a used cam and lifters together, and wouldn't see the need to "match" the lifters to the same bore. That being said, I haven't done it.
![](/forums/images/ranks/7k-10k.gif)
Received 1,949 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
I always *spin test* flat tappets also to make sure they turn. Plus I mic bores and lifters. Lots of stuff can get you messed up in valvetrains.
For sure the older design lobes are more forgiving. But there were *crazy* lobes back then too...and they didn't last too long. But to win races you used them. Not a lot has changed.
NASCAR cam cores are welded on each lobe. That's a several thousand dollar cam package and nothing like normal folks would use.
Some oils DO cling well after sitting around for a long time. Brad Penn is one of them.
JIM
JIM
Thanks for some great information. This would have been helpful a few years ago when I destroyed a newly build AMC 360 in my Jeep due to non zinc oil.
One thing did pop at out at me, NON STREET LEGAL oil? Is there an oil police out there somewhere? HAHA Thanks again.
![](/forums/images/ranks/1k-2k.gif)
540- i think your list needs to be turned into a sticky. You did some great testing of motor oils and how they performed against each other. This is a lot better than what the marketing gurus will try and tell/sell us.
