Diagnose Lower Control Arm Bushings?
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
My 77 pulls hard right under braking. My first thought was a left caliper but it seems OK; it clamps the rotor, no air in the line, and I can move the pads so I don't think a piston is stuck. My next thought was front suspension, but everything seems OK except the lower control arm rear bushings look iffy. Is there anyway to check or test the bushings?
![](/forums/images/ranks/1k-2k.gif)
From the little there is to see of the bushing, is the rubber is cracked, split, or are pieces missing?
Doubt the bushing is responsible for the hard right pull during braking. Seem more likely an asymmetry with the braking system rather than suspension.
Controll arm bushings are not prone to wearing out . If there is no obvious signs of a brake problem I would service the front brakes,replace flex hoses, new pads, turn rotors, rebuild callipers and clean, inspect and re-pack the bearings. Best to have the rotors turned on the hubs .
Great weekend project .
Bill
Bill
I'm going to start with a caliper this weekend. I have a new brake hose, but the brake line flare nut at the hose looks iffy and I'm nervous about messing with it. I'll have to take a look to see how far back that hard line goes before I risk stripping it.
I really can't see much of the suspension bushings, but I'm thinking worst case since the caliper seems OK. I hate parts that you can't test to get a definite go/no go!
The car pulling under braking is most likely not a bushing issue, chances are it's brakes. It may not be the left side, it could be that the right side isn't releasing, that the pistons are stuck, you should check both sides. Look for the obvious first, leaks, uneven brake pad wear, hot spots on the rotors, that kind of thing. Don't pull the rotors off the hubs unless you need to. Rotor runout is important on these cars and will cause you some grief if it's not in spec.
As for the hard lines, the left side isn't that long, about 18 inches or so, it only goes to the proportioning valve, and you can get them (along with every other brake part in the system) from most of the vendors.
![](/forums/images/ranks/11k.gif)
Received 1,471 Likes
Cruise-In II Veteran
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
I agree the problem does not sound like bushings. I also agree, while they may not wear out, bushings certainly die from old age and ozone goo.
If they look ugly, they probably are.
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
If the controll arm bushings were worn to the point that the car pulls under braking he wouldn't need to apply the brakes to know there was a problem . The car would rattle at every bump in the road .
Most controll arm bushings get replaced because alignment shops use them to turn a basic alignment into a money maker or someone thinks that polly bushings are a good idea . ( Not ! )
Bill
Bill
St. Jude Donor '07
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
Bill
Bill
I agree that this sounds more like a brake problem, but to say that rubber control arm bushings don't wear out or that poly bushings are crap is just silly.
Poly bushings are great...if you use them in the proper locations and don't buy garbage poly. I've had great luck with Energy Suspension parts on multiple vehicles.
What positions would polly bushings be great on a street driven car and where are Energy Suspension Polly Bushings manufactured ? Which ones are "garbage" ?
Please note that I said that they were not prone to wearing out not that they don't wear out, I also didn't call polly bushings "crap" .
I believe we are talking about a street driven car here .
I don't mind being "quoted" but please don't add words like crap to my opinion's .
Regards Bill
![](/forums/images/ranks/7k-10k.gif)
I've driven for at least 6 months with the lower rear bushing rubber almost all gone with the only noise produced was when braking the first time after going from reverse to forward or back. No brake pulling whatsoever.
If they look bad replace them as soon as you can, but you have a separate brake problem. Take a look at the opposite side brake.
St. Jude Donor '07
I have a couple of questions .
Regards Bill
Regards Bill
OK, you said that they aren't a good idea. I've had good experience with ES bushings in multiple vehicles, so I'd have to disagree.
Poly is good for areas that should only rotate and not deflect - control arms, sway bars, etc. It's also good in stationary locations - body mounts, pinion mounts, spring link cushions, sway bar end links, etc. Trailing arms and lower rear links deflect and rotate, that's why I used spherical bearings in those locations. I've had several cars with ES poly bushings in proper locations, including daily drivers, and have had nothing but excellent results.
Energy Suspension bushings are made in the US. Not sure about the no-name stuff sold by some vendors, and I've known plenty of people who have had issues with Prothane parts.
Sorry, I thought this was the C-3 Corvette Forum and we were talking about the front lower controll arm bushings of a Corvette .
My mistake, Bill
http://www.energysuspension.com/who-we-are.html
Nowhere on their site do they state that their parts are made in USA .
Just that their engineering and manufacturing are done in the same place .My guess is China.
Bill
My mistake, Bill
Bill
St. Jude Donor '07
![*****](https://www.corvetteforum.com/forums/images/smilies/willy_nilly.gif)
Bill
Bill
"We are proud to offer our customers the finest polyurethane suspension components available in the marketplace today. Our policy of manufacturing in-house from the initial R & D stages, to chemical formulation, molding and final packaging allows us to control every aspect of the manufacturing process. This ability produces a genuine American-made product and gives our customers absolute confidence in the ENERGY SUSPENSION name."
You can guess all you like. You'd be wrong.
Umm...on the page you just linked...
You can guess all you like. You'd be wrong.[/QUOTE]
My Mistake ,
I'd be wrong,
Your correct on that point.
I still would never put polly bushings on a street driven Corvette . Been there , done that on my own Corvette and have removed many from customer 's cars who cant stand the rattling, squeaking noises .
Again , Bill
My Mistake ,
I'd be wrong,
Again , Bill
![](/forums/images/ranks/3k-4k.gif)
My Energy Suspension graphite impregnated bushings have never rattled or squeaked. And they've been installed for 2 decades. I even R&R'd the bushings when I installed offset upper control arms to gain more positive caster during last spring's rack & pinion install. They still looked like new.
Well, I picked up a new caliper last weekend. When I went to install it, it was obvious the runner brake hose was in bad shape. When I removed the hose, it was obvious the stell line was in bad shape...a few hours later, though, no more pulling. I also checked the right side, and that hose was in bad shape as well. One more problem resolved, thanks for the help guys.
Glad you got it fixed, you really should consider doing the other side...doing just one is kinda like doing just one spark plug. All the others (unless they've been changed) are the same age and have the same wear and tear on them. Same for the hoses and master cylinder. You can do one axle at a time to limit the cost.
St. Jude Donor '07
My Mistake ,
I'd be wrong,
Again , Bill
I'd be wrong,
Again , Bill
GOOD poly, properly lubricated with the sticky grease sold by ES, simply doesn't exhibit the problems you describe.
