68 tire size max.........
![](/forums/images/ranks/7k-10k.gif)
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Hi guy, just a quick couple of questions on my buddy's BB 68. 8 inch rally wheels, stock trailing arms. What's the widest 65R seiries tire you can run? I know 235's will work, but is that the widest? Thanks.
Second, where's the best place to get the longer spring hang bolts? The car has aluminum spacers on the diff and cross member, and sits a little high. Thanks.
This is for the 468-500+ mill we build last summer if you recall.![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
![](http://oi49.tinypic.com/343t89k.jpg)
![](/forums/images/ranks/5k-6k.gif)
65R???
I've seen people force as wide as 295/50's onto 8x15's, but the widest secton width I'd suggest putting on an 8" rim of most any diameter is 255mm. IMHO it's hard to beat either 245 or 255 /60's on 8x15's, tho the latter have been known to rub up front on occasion.
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
65R???
A solid diff locating kit (aka "pucks") should be beneath rather than above the diff cross-member with one replacing the pinion bracket rubber, doesn't really do all that much harm to comfort other than transmitting more noise and vibes into the chassis, and doesn't affect ride height at all. The only ones that go between the x-member and frame are those used for replacing the rubber bushings outright and facilitate raising the diff in the chassis to improve rear suspension geometry on lowered (rather than lifted) C2/C3's, and AFAIK shouldn't be visible.
![Toe Tap](https://www.corvetteforum.com/forums/images/smilies/toetap05.gif)
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
It would seem so. If still that high with the suspension settled, first suspect I'd check out would be an overly arched spring, but then maybe they've gone and done something odd with the rear suspension. Pics would be very helpful, if at all possible.
