Hi...
I was trying to install the cable & lost the bolt for it, I've been trying to find it. Also i took out the other unknown bolt & lost it like a dummy. does anybody know the kind of bolt sizes i need ? (Pic 1)
2nd question... Is my detent kickdown cable attached correctly (wire) (pic 2) ???
any help is much appreciated 🙏 Pic 1 Pic 2
The hole towards the rear is the sensor port (pressure typically, 1/8 npt)
If it's not metric trans (no idea what year you have) then the bolt should be 1/4-20, pretty short like 3/8-1/2 long
M
