How much power/torque can a Turbo 400 handle?
![](/forums/images/ranks/3k-4k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Looking to build a blown 406 small block but if my drive train can't handle the power, whats the point? I am also concerned about my stock spindles.
interpon (03-08-2020)
![](/forums/images/ranks/11k.gif)
My dad had no problems with his stock Th400 behined a 750hp Big Block in his Street Rod. :cheers:
![](/forums/images/ranks/5k-6k.gif)
If it goes you can always rebuild (it's cheap, Th400 are VERY common) and have a damn near bulletbroof transmission.
Thanks for the info.
TH400's are not common, twenty years ago mayber but try to find one. Not all TH400's fit chevy's so you do see a lot of them that are pontiac/olds. Even Jag's used 'em but they won't fit Chevy's.
![](/forums/images/ranks/100-500.gif)
I guess it all depends on location. They are a dime a donzen here, you can buy them all day long for $400-$500.
GOOD rebuildable Chev TH400 are tough to find. Almost all are junk not worth rebuilding
Cruise-In IX Veteran
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
A Th400 is a brute as far as trannys go. I would not be scared to put a stock Th400 behind that 406. If it goes you can always rebuild (it's cheap, Th400 are VERY common) and have a damn near bulletbroof transmission.
"How much power/torque can a Turbo 400 handle?"
Easy answer: More than any smallblock could EVER give it. :D
Actually, they have gotten LESS expensive, since everyone is installing slip 'n slide Powerglides now. THAT change was sometrhing that I would NEVER have predicted in a zillion years. The Powerglide was always the standing joke among hot rodders. I guess maybe people get off on that "one big shift" :lolg:
I wouldn't even bother looking in a boneyard for a Turbo 400. You can get one in Jegs for around $725-$750 already built.
Dep
Dep
platinummaker (08-24-2020)
My dad had no problems with his stock Th400 behined a 750hp Big Block in his Street Rod.![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
Received 3,043 Likes
St. Jude Donor '05
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
When burninig out its usually when the tires catch up that trannies go.
As said a stock T400 can handle some beans. If they can hold up to strain of large motorhomes a 400ish hp toy wont hurt it none. Use a good trans cooler heat is the enemy on most trans.
THM-400's are bullet proof. But they are also heavy and very inefficient. You would do better to go with a well built 700-R4, IMO.
![](https://www.corvetteforum.com/forums/images/ranks/veteran_navy.png)
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
kind like demographics ... some places are choked w/ one sort of "hyphenated" americans ... while you have to hunt for em in others. 400's are relatively heavy & inefficient ... but Very tough
If an overdrive is preferred, a 4L80-E is successor to tough TH400... but requires a controller ... and many were mfd after the TH400 era; theoretically should be more available.
https://en.wikipedia.org/wiki/GM_4L80-E_transmission
Dr. Detroit
Received 3,904 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
Read this....
https://www.motortrend.com/news/1969...e-lt-2-review/
Although this is the clone.......the magazine testers of the day got the original to run 10.60's on slicks by revving it to 7000rpm and throwing the shifter in drive from a dead stop. It has a Th400 in it. There were next to zero aftermarket components for the TH400 in 1970.......I think that answers your question.
Jebby
Jebby
4L80e is the electronic equivalent of the 700-R4. They are basically the same transmission with electronic selection of ranges and shift points on the 4L80e. There is no later equivalent of the THM-400. Too expensive to make and too heavy/inefficient for the "fuel efficient" paradigm.
4L60E is electronic 4L60 fka 700R4 ... all good transmissions but neither as robust as following trans and have different ratios than below trans as well
these also have a markedly deep first gear ratio.
4L80E is an electronic version with OD of 3L80 fka TH400 ... all VERY robust
4L85E is a much higher torque version of 4L80E ... either VERY robust; 4L85E even more so
with exception of addition of an .75 OD ... both 4L80E & 4L85E have identical (1-2-3) ratios as 3L80/TH400
in addition to OD, those with OD also a lockup torque converter
Yes, this is a very old thread. 17 years.....hard to believe that much time has passed. I still have my Turbo400 but it sits on my garage floor. I have since been through a 200r4 (also sitting on the garage floor) and now am running a TKO600 5 speed behind a 434 SBC. I miss the Turbo400. There was something special about just mashing the gas pedal and hanging on for the ride that I really miss.
