Fog Light Lens
![](/forums/images/ranks/2k-3k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I've heard that you can sand and polish them. I wouldn't use anything coarser than 600 grit to start with. Work your way toward 2000 grit and use the normal scratch remover and polish.
Shouldn't be too much work if you are patient.
Good luck.
Good luck.
