Changing Serpentine belt
![](/forums/images/ranks/7k-10k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
Lift the belt tensioner pulley upward (clockwise). Use a socket and a handle on the tensioner pulley bolt.
Here is a diagram from the FSM for a '96. I believe the '94 is the same.
![](http://i15.photobucket.com/albums/a391/RollaMo-LT4/001-1.jpg)
![](/forums/images/ranks/11k.gif)
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
Take care you don't break off your coolant temp (guage) sensor, too. It's easy to do if you're not careful.
Helps to have a helper remove the belt as you apply tension until you get the hang of it.
![](/forums/images/ranks/4k-5k.gif)
1 Post
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Hi- You really should get a serp belt tool/wrench as opposed to using a socket on a ratchet unless you have a pipe slipped over the end of the wrench for leverage. Even then, the belt tool is slender and just works better. The length of a belt tool gives you that leverage to do it with ease! You can get one at any decent auto parts house for about $30 +/-. It is well worth the price if you work on your own car....
![Smile](https://www.corvetteforum.com/forums/images/smilies/smile5.gif)
![](/forums/images/ranks/5k-6k.gif)
Hi- You really should get a serp belt tool/wrench as opposed to using a socket on a ratchet unless you have a pipe slipped over the end of the wrench for leverage. Even then, the belt tool is slender and just works better. The length of a belt tool gives you that leverage to do it with ease! You can get one at any decent auto parts house for about $30 +/-. It is well worth the price if you work on your own car....![Smile](https://www.corvetteforum.com/forums/images/smilies/smile5.gif)
There is likely not enough room to put a socket on the tensioner bolt anyway. When I tried, there was a crossmember in the way.
![](/forums/images/ranks/100-500.gif)
![*****](https://www.corvetteforum.com/forums/images/smilies/willy_nilly.gif)
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
1 Post
![Wink](https://www.corvetteforum.com/forums/images/smilies/wink5.gif)
St. Jude Donor '08-'09
![Agree with stupid](https://www.corvetteforum.com/forums/images/smilies/iamwithstupid.gif)
Clearance is the issue with the socket method, you have to basically use a breaker bar,but then you can run into clearance issues and othe things to get it pushed down far enough.
