Bleeding Cooling System?
Old 04-28-2016, 07:41 AM
WW7
WW7's Avatar
Originally Posted by Timg203
Do you happen to know where the coolant bleeder valve is on a 1986 corvette?
The early C4s don't have a bleeder valve...You have to use a method called " Burping the system" there are threads on doing this if you do a search in the archives....Below is what I use for all my vehicles including my 89 Corvette.. This makes filling your cooling system a 10 minite job, because your not allowing any air in the system from the start.......WW
Amazon.com: UView 550000 Airlift Cooling System Leak Checker and Airlock Purge Tool Kit: Automotive Amazon.com: UView 550000 Airlift Cooling System Leak Checker and Airlock Purge Tool Kit: Automotive
Quick Reply: Bleeding Cooling System?
