1984 Windshield Wiper Switch Question
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
My windshield wiper switch only works on the "Low" and "High" settings. When it is in the "Delay" position, nothing happens.... Any ideas?
Thanks!
Thanks!
![](/forums/images/ranks/4k-5k.gif)
Mine has the same problem. The switch does look really flimsy so I'm leaning toward a bad switch. The switch feels like if I press too hard I'll break it type of feel.
![](/forums/images/ranks/3k-4k.gif)
More than likely, this is not a awitch problem, but rather a ciruit board problem. Try your windshield washer. If it doesn't work either, that would point to a board probem as well. The board is part of the cover of the wiper motor, and is not a serviceable part. Replacements are expensive.
![](/forums/images/ranks/1k-2k.gif)
Replaced the wiper switch, the circuit board ..no change
I tested mine by turning the wipers on and tapping on the wiper motor with a screw driver and it worked..for awhile...
Later I replaced the wiper motor..and no problems since
Stay safe
Rick
![](/forums/images/ranks/5k-6k.gif)
Location: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
My wiper on my `87 is crappy also. Usualy when I shut it off, it won`t return to the "park" position. It just stops where it feels like it. I`m wondering if a setup from a different/newer GM vehicle could be made to work in these cars.
![Big Ears](https://www.corvetteforum.com/forums/images/smilies/bigear.gif)
My washer doesnt work but the delay does so I am hoping its the pump. Unfortunately I think GM adaptation of the switch is gonna be tough as most wiper switches are on the directional stalk off the steering column. Never in my life have I seen the wiper switch on the door.
![](/forums/images/ranks/2k-3k.gif)
my '84 delay works but the washer doesn't.
pulled right fender and ran batt/grd directly to the pump and paid the price for not checking where the hose was pointing-wet face! looks like I'll check the board next as 92ragtop suggests!
