Interior lights stuck
My interior lights are stuck on , after all doors are shut , but i can get the lights to go off after i lock both doors? Any insight as yo what might be wrong? 1992 corvette
makes driving at night hard
There is a somewhat common C4 issue with the door switch that could be the culprit. I would start there since there are several write-ups on it and that may be the easiest to eliminate.
https://www.corvetteforum.com/forums...-old-news.html
Make sure the outside key hole slits are perfectly straight up and down. I had the same problem and that was the fix. Apparently there is a switch on them that turns the lights on when you unlock your doors.
Andrekai000 (01-28-2020)
