C4 Head unit/stereo options
So, since my 85 is missing the head unit, what have some of you installed in your c4's. I would like to have a double din touch screen but doesn't look possible. Just thinking ahead, it is part of the interior that needs replaced.
BT1991 (02-01-2020)
I purchased a Soundstream unit from fleabay with a flip up screen. Not a high end unit but so far I am pleased with the performance. I believe I paid around $190 for it. I just needed something with a screen for the backup cam and did not want to do all of the modifying to fit a double din unit.
Did you have to do anything to the security system what you replaced the stock unit? I recall reading about issues with swapping out a '93, but not where I saw it.
Jerry
Jerry
Edit: Looks like a bit more than $300 for the parts. But.... There are several things that I already have covered using my phone (ALDL, GPSf) and that knocks off at least $60 right there. Hmmm. Still need am amp of some sort, and some way to attenuate the output so that I can use the existing speakers.
Edit: https://www.corvetteforum.com/forums...eleased-2.html
