1990 Iroc 700r4 tranny fit 1996 corvette lt1?
Hey again.
I posted this 700r4 (I think it's an electronic version from what I remember the shop telling me who rebuilt it) from my old 90 l98 iroc on the c4 for sale section knowing of course that the transmissions were similar, but not the same as in the vette. Perhaps I should move it to another forum section but I wasn't thinking.
Now, this got me thinking. Will that transmission work in my 1996 corvette if I trade out the tailshaft or are there insurmountable differences. Reason I ask is that I know that transmission shifts very hard and the one in the vette has 70k miles on it and is starting to show signs of weakening.
If it won't work for me and my 96, are there any years that it will fit for the vette? Maybe 1990/91 since those motors were more similar to the iroc?
As you may know, I am going to be putting the lt4 engine in behind my original lt1 a4. But these 2 transmissions are not side by side right now, so I don't know if there are other differences. I'm sure the lt4 is going to bring my aging 70k tranny to its knees in no time.
thanks for the information in advance!
Originally Posted by torchred96
Hey again.
Ah, so I have a half breed. Thanks for clearing that up.
Now, what about diffences to fit a vette from 93 down?
tailshaft..anything else?
thanks.
Sam
thanks.
Sam
St. Jude Donor '05-'06
Yes tail shaft & governor(recommended) at least .Some will say you need to cut the splineshaft some say no.Valve body if you want it to shift like your vette.I believe you could put it in a 96 too.You would need this
http://www.tvmadeez.com/index2.html
to replace the electronic shift.I do not think the speedo is an issue if you swap it out could be wrong though.
Originally Posted by ToddC4
Where do you plan on bolting up your trans to diff C-beam since your Vette doesn't have a trans crossmember and the F-car does?
When I bought the Corvette initiallly, it was hit in the front end.. turns out it had also broken the tail shaft from the impact.... I think I paid about 100 for a new one that I put back on myself. I think I had to have a bushing and or seal pressed in or may have done it myself. I can't remember. I'm pretty sure, that that part wouldn't be problem.
Does anyone know if it would cause codes to come up on the 96?
I'm thinking that I may be able to use the lt4 computer in my lt4 swap...and use this 700r4 trannny....This is getting ugly.
Originally Posted by Pete K
You cannot use a non electronic trans in an electronic trans car.
It will fit , the C beam will bolt up if you use the Vette ext housing ,but it will not be electronically controlled by the '96 computer.
As stated you could hook up the TV cable as in the earlier non elec setup but I do not know if the computer gets any feedback from the trans other than VSS which is the same on both types.
sounds like i should trash that idea. just a passing thought. I will spend the money i guess and have my 96 tranny done when the time comes.
thanks again.
thanks again.
