Battery, Starter, or Altenator?
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
My 1990 L98 is starting to get finnicky when I try to start the engine. It seems that if the engine is good and cool she will start up fine but if i stop, say, to get gas and then try to start her up again she won't start. If I turn the key to the on position the power in the car works it just won't start. I have had to push her off four times today and it's starting to get annoying and embarassing to have such an awesome car but i have to push it off to start it.
![Toe Tap](https://www.corvetteforum.com/forums/images/smilies/toetap05.gif)
![Ack!](https://www.corvetteforum.com/forums/images/smilies/ack2.gif)
![](/forums/images/ranks/5k-6k.gif)
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
![](/forums/images/ranks/11k.gif)
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Reading between the lines it sounds like you're saying it's not cranking over when hot. This is usually a bad starter solenoid. It can also be a bad battery cable connection, but less likely.
The starter solenoid is part of the starter assembly, the whole thing would be replaced. About $120.
When I turn the key there is nothing, no click no hum just silence. I'll try tapping on the starter if it hapens again today. Usually it only hapens when I don't let it cool down for more than a few hours.
