alternative serpentine belt setup?
im trying to come up with a way to remove my a/c compressor and do the smog pump delete at the same time
is there a way to re run the belt so i dont have to install delete pulleys in there place
searched for smog pump delete found nothing
Received 3,043 Likes
St. Jude Donor '05
If you want to delete the A/C and smog pulleys at the same time you will need a standard rotation WP. You'll also need some kind of tensioner. I fabbed up a slotted one that tensions just like an older car (pry the alternator in place and then tighten). You can also use a bar with heim-joints at each end.
A WP from a 1982 vette is standard rotation and fits right in for any L98 setup.
Neither, actually. You're not making a tensioner with it's own pully, you're tensioning the system by rotating the alternator. So the tensioner goes between the alternator and the block.
Originally Posted by conv90
I read the link and the others links in the link.
What i don't understand is if always is needed to swap to a standard rotation WP...
-Beppe-
-Beppe-
RACE ON!!!
I wonder if the parts would be available to convert your pump from one rotation to the other. Could the impeller just be removed and pressed back on upside down?
